wind noise following door glass install
My 1999 camry left front window was vandalized and I replaced with a used window that was advertised as a 2000 window. Not sure if I'm just imagining things, but even though the window seems to fit just fine, it seems like there is now significantly more wind noise on that side at highway speeds. Is there any difference between a 2000 and 1999 window? Are they exactly the same? I figure even a slight difference could result in the wind noise, even if the window seems to operate fine.
