Tire size - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-23-2006, 06:04 PM   #1 (permalink)
View jmp0126's Photo Gallery
3rd Generation Tire size
Hey TNers,
I'm planning on purchasing new wheels/tires next month from TireRack. Wheel size will be 18x7.5 recomended tire size 215/45/18. Was wondering if the 225/40/18 will fit with no problems aka rubbing against struts/springs. I will be lowering the car with Eibach/Tokico combo. Thanks for your input.
jmp0126
jmp0126 is offline   Reply With Quote
Old 05-23-2006, 06:15 PM   #2 (permalink)
Turbo S2000 FTMFW
ECale3's Avatar
iTrader Score: 10 reviews
View ECale3's Photo Gallery
i have 225/45ZR17's on my car, if you went with 45 series tires on 18" rims would that throw off your speedometer? I have 45 series tires on my 17's, when i was looking for rims, had i gone with 18's i would have gone with 40 series tires (I have a gen 3.5 by the way).
So i would recommend using the 40 series, and 225/40/18 should fit no problem. Also, since you are looking to get rims you wanna make sure the rim offset is correct otherwise you will have problems with rubbing etc.
The worst part of dying is being alive.
ECale3 is offline   Reply With Quote
maximum size of tire for a 16 inch rim? Matus1 89-95 Toyota Pickup/Hilux 2 07-17-2009 05:16 PM
tire size? andriod8000 1st Generation (1995.5–2004) 1 03-01-2006 08:34 PM
Tire size comparison calculators HoustonHokie 2nd Generation (2005+) 4 02-24-2006 01:22 AM
Stock ae92 Sedan tire size Phreshnphunky Archived Corolla threads 3 01-29-2004 08:37 AM
