How long do platinum spark plugs last? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-24-2006, 01:52 AM   #1 (permalink)
'00 Camry V6 (1MZ-FE)
View NewRacer's Photo Gallery
4th Generation How long do platinum spark plugs last?
How long do platinum spark plugs last? 50,000 miles? The second owner bough the car as "certified used vehicle" at 34217 miles, do dealers do a tune-up and change spark plugs before they labeled it as "certified"?
I just bought my car at 69k miles, I'm thinking maybe I'd wait a little longer before I do a tune-up and change the spark plugs. Or should I do it now? It has 71k now.
NewRacer is offline   Reply With Quote
Old 05-24-2006, 06:11 AM   #2 (permalink)
2007 RED Camry XLE Owner
Old Dood's Avatar
View Old Dood's Photo Gallery
They are "suppose to" last 100K miles. I always change plugs at 50K miles. Why not? They are not that expensive. Also I put in the Iridium plugs...they are suppose to be better then platinum ones.
Also check your fuel filter...that should be change even more so then the plugs.
"We can't solve problems by using the same kind of thinking we used when we created them." Albert Einstein
Old Dood is offline   Reply With Quote
Old 05-24-2006, 11:32 AM   #3 (permalink)
Gameroom cash: $304355
The manual for my 98 recommends changing the platinum plugs at 60,000 miles. I did mine at that mileage and they looked light they were brand new. That said, I'm not sure I would want to try to get them out of the head at 100,000 plus miles, so 60,000 or so sounds like a good time to do them. Incidently, in my area Autozone had the best price on one of the 2 dual ground electrode tipped plugs that were recommended in the manual.
Mike
Mike Gerber is online now   Reply With Quote
Old 05-24-2006, 11:38 AM   #4 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
after you do your seaform treatment (prferabled a two weeks later to be precise).
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 05-24-2006, 11:45 AM   #5 (permalink)
drunken member
CCCP's Avatar
View CCCP's Photo Gallery
I think it's way too expensive to change them every 50k on a V6
CCCP is offline   Reply With Quote
Old 05-24-2006, 12:20 PM   #6 (permalink)
Camryologist
ptycamry's Avatar
View ptycamry's Photo Gallery
I changed the spark plugs on my V6 for the first time when my car had 96,000 Km...
I put in Denso IK-20 Iridium Plugs...
The stock plugs where still good to go, but I decided it was already time for them to go.. hehe..
I'm not planning to change them for a really long while, for sure, more than 50,000 miles...
ptycamry is offline   Reply With Quote
Old 05-24-2006, 02:55 PM   #7 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
my haynes manual says to check plugs every 15K but does not specify how long the plus would last. Wires are to be checked every 30K and replaced as necessary.
I took out my denso plats that were probably replaced at 60K, and they look browned, kinda burnt but not black. So do i need to change them? I'm at 97K currently.
nodrogkam is offline   Reply With Quote
Old 05-24-2006, 04:14 PM   #8 (permalink)
97 Camry
View Davee's Photo Gallery
I think the 50,000 mile change out is premature . I am at 197,000 Km & changed them once. A spark is a spark -- If it works leave it alone Color means nothing about the plug but does tell you if brown-- You are getting good fuel/air regulation. I ran a six cylinder truck with different plugs in each cylinder -- They all did the job
Davee is offline   Reply With Quote
Old 05-24-2006, 06:52 PM   #9 (permalink)
Old Dood's Avatar
Well i will change out the plugs at 50K. It is the "Old" in me that does that. It is not that expensive to do either. (Same with a fuel filter...every 25K. Never know what kind of dirty gas you get. No one can tell me these Gas Stations have clean main tanks. ) I rather have cleaner burning plugs then the chance they get all fouled up. More then one person drives the cars here. Mrs Dood is a lead foot in town...she thinks ever car we have is a sports car.
I am anal about oil changes too. Even though I get more highway miles I will still change the oil every 3K no matter what.
190,000 km - 1st spark plugs change ToyotaToday Camry & Solara Lounge 8 04-22-2006 11:56 PM
Change Spark plugs on V6 GEN5 ToyotaToday 5th & 6th Generation (2002-2006 & 2007-2011) 8 04-12-2006 08:26 PM
When to replace spark plugs... MustangDave Camry & Solara Lounge 2 02-01-2006 10:49 AM
platinum plugs jtl MR2 Forum 15 11-11-2004 10:44 AM
changed spark plugs... engine light came on. sexydarin Archived Corolla threads 2 10-30-2003 06:21 PM
