oil pan gasket question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-24-2006, 08:45 AM   #1 (permalink)
Meet My GF...Camry
View NowUCMeNowUDont's Photo Gallery
would a high heat temp gasket maker work fine for reinstalling the oil pan??? the stuff i bought is an orange color
NowUCMeNowUDont is offline   Reply With Quote
Old 07-12-2006, 04:58 PM   #2 (permalink)
95% Biker / 5% Driver
Digger1's Avatar
View Digger1's Photo Gallery
Exclamation
If it is Permatex Ultra-Copper
http://www.permatex.com/products/aut...sket_Maker.htm
then you should be good to go. This stuff has never failed me!
Digger1
"If you don't understand the technology you depend upon, you will someday be a victim of that technology."
Digger1 is offline   Reply With Quote
Old 07-12-2006, 05:52 PM   #3 (permalink)
Gameroom cash: $133300
View profuse007's Photo Gallery
yeah thatll work fine if you know how to put it on correctly.
1.scrape off everything from the block to pan.
2.put a bead of high temp silicone
3.mate the pan to block and hand tighten the bolts, this will give a space of about 1/8" or 3/16" for it allow to semi-cure.
4. wait for ~1/2hr and then tighten it to specs.
or you can alternatively get a cork gasket for ur pan, but i like the silicone better.
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
Oil pan gasket gone? Camryfanatic Camry & Solara Lounge 23 06-11-2006 01:08 AM
HELP.... oil pan leaking asousa 1st Generation (1995.5–2004) 1 02-08-2006 05:34 PM
Synthetic oil question Raddman Archived Corolla threads 29 01-10-2006 04:38 AM
Oil Drain Plug Gasket rickmadison Camry & Solara Lounge 5 05-09-2005 11:50 PM
3s-ge oil pan gasket `d3x Hardcore Tech and Competition 6 03-02-2004 07:35 PM
