Trouble with the CEL - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-24-2006, 08:59 AM   #1 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
4th Generation Trouble with the CEL
I'm currently a little short of funds to get the CEL code pulled but perhaps someone could tell me what my issue could be.
So 2 possible things run through my mind.
1. Ebay intake that leaves one of the intake hoses unused causes the CEL. However it didnt cause it during the first 500 miles of use. So im sort of ruling that out. Idle, performance etc is pretty ok.
2. I bought a resistor off of ebay to 'trick' the intake sensor into thinking i the air it's taking in, is 10 degrees colder than it actually is. I havent used it in a while, but the first resistor i put in caught fire and singed the connecting harness. That initially caused a CEL, but after a reset, the light didnt come back on. Using another resistor it hasnt caused a CEL. But for the last 1000 miles i havent used a resistor.
Okay so i havent been keeping a log but it seems to me that about every 500 some odd miles the CEL turns on. And it seems to turn on when i sit idle at a stop light with the A/C on.
I just switched to the OEM intake box yesterday and i'll monitor...but its kind of wierd this is happening. Thanks for any input.
nodrogkam is offline   Reply With Quote
Old 05-24-2006, 11:34 AM   #2 (permalink)
Gameroom cash: $304355
"I'm currently a little short of funds to get the CEL code pulled"
If you have Autozone in your area they will do it for free.
Mike
Mike Gerber is online now   Reply With Quote
Old 05-24-2006, 02:53 PM   #3 (permalink)
nodrogkam's Avatar
yeh i can do that but they charge 100 dollars deposit, and they wont actually do it for me, i do it myself.
i guess i can do that if it happens again. thanks.
Old 05-24-2006, 08:39 PM   #4 (permalink)
View foompla's Photo Gallery
i think you answered your own question.
its probably an evap code.
foompla is offline   Reply With Quote
Old 05-24-2006, 10:45 PM   #5 (permalink)
nodrogkam's Avatar
haha
30 miles into the cel after i changed back to the oem intake took away the cel.
me thinks i've found the problem haha
'91 CEL (check engine light) kamesama980 Archived Corolla threads 5 04-20-2006 11:21 PM
trouble, trouble and trouble with 3vz-fe gbaoyn Camry & Solara Lounge 13 04-20-2006 09:26 PM
CEL Mystery Mousiee Camry & Solara Lounge 0 10-05-2005 06:07 PM
cel 05 xrs mmartin1872 Archived Corolla threads 0 07-24-2005 09:34 PM
2004 CEL - VVTI problem bluemm Archived Corolla threads 2 10-18-2004 09:32 PM
