Originally Posted by JayMax03
Are there automatic shift knobs for a Camry LE (92)? How do you change them out?
My wife's 93 SE never thrilled us with its vinyl blob of a shifter. I bought a stock ES300 shift knob, real leather wrap and such. The nice thing is it retains a very clean, OEM, looks like it belongs there kind of look. It took a bit of rework-- the metal tube upon which the shifter mounts is shorter in the ES than the Camry, by just a little bit. And there is a white tapered piece that mounts atop the shift release pin that had to be tweaked a bit. It looks pretty sweet now-- more like the XLE from later years in the Gen3 range.
Otherwise, you have a lot of aftermarket options-- I'm not sure how exact any of them will fit, since (I think) they're pretty universal.
And the last question is why in the blue hell is my acceleration pad sticking???? I keep have to put it in neutral and put an light press to it to get working normal again!!! I tried some WD-40 but it didn't last long!
I assume you've looked at the pedal and everything underneath to make sure you don't have an old banana wedged under there, right? What are you WD-40'ing? deekay140 suggested cleaning the throttle body-- I'd also take a look at the throttle cable itself, under the hood, to make sure it isn't gummed up.
