Easiest way to get to spark plugs!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-24-2006, 06:18 PM   #1 (permalink)
View 89_3SFE's Photo Gallery
Okay, I really thought this job would be easier until I looked under the hood of my V6 91 Camry (2VZFE engine), and found out that 3 of the spark plugs are way back underneath the intake manifold. What's the easiest way to get to all of the spark plugs to replace them?
89_3SFE is offline   Reply With Quote
Old 05-24-2006, 07:03 PM   #2 (permalink)
View edmonton99's Photo Gallery
I haven't tried it yet but I heard some people can reach around and get the first 2 from the driver's side and the 3rd one from the passengers side. I'd use a swivel socket and an extension to remove them and make sure when you tighten the new ones do it without the wrench first so you dont cross thread anything. goodluck, i'll tell you how I did it when I do them which will probably be this weekend.
1990 2.5L V6 Canadian 25th anniversary http://img501.imageshack.us/slidesho...5625366ym.smil
edmonton99 is offline   Reply With Quote
Old 05-24-2006, 09:46 PM   #3 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $280492
View csaxon's Photo Gallery
http://www.solaraguy.org/viewtopic.php?t=10551
Might help.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 05-25-2006, 01:37 AM   #4 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Easiest way is to remove the intake plenum.
Some people can manipulate a tool around the back of it and remove them, but i find it very fiddly. Once you get the knack of removing the intake/associated lines/hoses, then its a sinch.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
How to change spark plugs on 1MZ-FE under 1 hour albertezza Camry & Solara Lounge 25 06-23-2011 08:51 PM
Denso Spark Plugs for 1MZ-FE ptycamry Camry & Solara Lounge 10 01-05-2006 02:26 AM
Iridium Spark Plugs!?!?!!? Matsu-Seo Yaris, Vitz and Echo Forum 6 12-03-2004 09:52 AM
spark plug wires + spark plugs aleks77 Camry & Solara Lounge 4 09-13-2004 02:08 PM
changed spark plugs... engine light came on. sexydarin Archived Corolla threads 2 10-30-2003 06:21 PM
