3vz-fe problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-25-2006, 02:36 AM   #1 (permalink)
Sp33dFreak's Avatar
View Sp33dFreak's Photo Gallery
3rd Generation 3vz-fe problem
The story goes like this .. Not long time ago i bought 3vz-fe camry , previous owner had messed up its idle stop screw and tps.The original Idle stop screw*(throttlebody stop screw) is replaced. Now the problem is .. i cant adjust the damn tps sensor whithout setting screw to factory default.Anyone with 3vz-fe , could you just measure the lenght of the screw in millimeters , for a better understanding wtf im talking about i attached this image ..
thankyou
Sp33dFreak is offline   Reply With Quote
Old 05-25-2006, 12:27 PM   #2 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
i'll use a feeler gauge when i get home and post back.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 05-28-2006, 03:52 AM   #3 (permalink)
Sp33dFreak's Avatar
Still wating for help..
Old 05-28-2006, 11:38 AM   #4 (permalink)
kor-ro-ra?
midnightmach's Avatar
View midnightmach's Photo Gallery
Yea i don't understand, lol tell me exactly what to do and i can help you. Real pics please?
RIP Corolla & Camry.
midnightmach is offline   Reply With Quote
Old 05-28-2006, 02:06 PM   #5 (permalink)
Sp33dFreak's Avatar
need this screw's lower part measured ..
(my screw is custom , yours is toyota original with yellow paint on it)
Hope this helps ... cant get more specific than this
thankyou
Old 05-28-2006, 08:48 PM   #6 (permalink)
kor-ro-ra?
ok ill get it to you tomorrow. i won't forget.
Old 05-29-2006, 02:04 PM   #7 (permalink)
kor-ro-ra?
Its touching the metal below it about 4-5 millimeters.
Old 05-29-2006, 04:43 PM   #8 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
In my 2VZ handbook, it specifies that to adjust this stop screw...have the throttle closed and screw it in until it just touches, perhaps only moving the throttle lever by 0.5mm or so.
Ive always wondered the point of this screw....what is it supposed to do. If you back off completely, IE take it out, the throttle still stops at around that point.. so whats it do?
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 05-30-2006, 01:21 AM   #9 (permalink)
Sp33dFreak's Avatar
Its touching the metal below it about 4-5 millimeters. .. well
the thing is , seems like you did measure it when engine running .. then ofcourse they are in contact , because the vacuum from intake draws one vacuum thingie and then the lower plate moves up (rpm will drop , idle mode) Thats why u cant just say hey it touches it really will not give me any info
when engine off there should be a gap between the lower plate and the screw .. and i could use exact length of the lower screw , cause anyone whos adjusted tps knows how damn accurate it must be
adjusting it involves putting 0,5 mm sheet between the screw and lower part at 0.3 mm we do 1 check and at 0.7 mm other one ..so its damn accurate ..
as for adjusting this screw like in 2vz ... i think its never meant for adjusting ..idle is ecu controlled , and idle bypass screw is on another location
so ,, with engine off .. just check it again (and real measurment would rock)
now as i have heard ..the stop screws one point is to stop the throttlebody's air flap movement arm from going too far up ..cause when you remove the screw .. the flap closes with a certain amount of force and lets the flap close too hard/too mutch pressure and it will rub channels inside your throtlebody ..so it should adjusted so that the throttleflap just barely closes and disables airflow
thanks so far tough ..
Old 05-30-2006, 08:11 AM   #10 (permalink)
kor-ro-ra?
ok. i measured it while the engine was OFF, and there is no gap...so believe what you want to my car runs fine.
Old 05-30-2006, 08:41 AM   #11 (permalink)
Sp33dFreak's Avatar
well i believe you .. cause i havt seen my system working yet .. the thing is .. when i set the screw like that (no gap) ..then the idle rpm is like 900/950 ... should be 700+-50... maybe the damn ecu takes it so long to learn (resetting ecu every time)..ill try it out , but for inurance could you just measure the screws' lower part too with feeler gauge or smthng ..
thnx
problem with 5th gear (manual) afan Camry & Solara Lounge 6 11-21-2005 10:15 PM
vacuum leak problem...also electrical problem related. afyouthbrigade Camry & Solara Lounge 5 11-03-2005 01:45 PM
87 Corolla hesitation problem. Bad_dude Archived Corolla threads 8 10-25-2004 04:31 PM
94 corolla electrical problem al_sniperrolla Archived Corolla threads 0 10-16-2004 10:42 AM
