those resistors or potentiometers just alter the voltage coming from the MAF sensor basically lying to the computer that there is colder or more air coming in then there actually is.
what happens?
the computer believes that its gonna get the air that the MAF is lying about and adjusts the fuel and timing accordingly... then what happens when it doesnt get that air? a rich condition.
not only will you lose power and waste gas, but you will foul up your O2 sensors and reduce the life of your catalytic convertor.
it does no good, only harm. UNLESS of course your car is running lean and there is nothing the ECU can do about it so in that case it is a solution, but what you dont understand is that the ECU is your friend and if you acutally knew how well it functioned, you wouldnt even waste your time reading about this useless mod and instead you would try and figure out ways to get more air (compressed
) into your engine and let the ECU and MAF do their job.
