power steering pump leaking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-25-2006, 01:18 PM   #1 (permalink)
View sche270's Photo Gallery
P/S fluid is leaking out around pump housing could it just be the gasket or is the pump going out, the pump works fine before the fluid leaks all out
sche270 is offline   Reply With Quote
Old 05-26-2006, 06:27 AM   #2 (permalink)
View Dave G's Photo Gallery
Take it to a DIY spray car wash and clean the area real well. Drive it and check to see exactly where the fluid is leaking.
You could try just changing the gasket and see if that fixes it. If not, then try replacing the whole pump. Shouldn't cost too much if you do it yourself.
Dave G is offline   Reply With Quote
Old 05-26-2006, 02:52 PM   #3 (permalink)
dave
thanks dave i'll try that
Old 05-26-2006, 03:36 PM   #4 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
NO - don't try that. in all honesly!
1. Buy high pressure hoses from an autoparts stores ($35 per hose)
2. Replace high pressure p/s hoses with new ones
3. replace all gaskets.
3. then refill fluid
4. then take it to a DIY car wash thingie and clean away!
High pressure hoses do give away on camrys as they age! (more so than the pump).
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 05-26-2006, 08:37 PM   #5 (permalink)
View Gary_602Z's Photo Gallery
^ WTF? Any mechanic that is worth his salt will determine the problem first before replacing parts willy nilly. This type of diagnostics is what will come back to bite you in the ass!
Do like Dave G said and determine the problem first.
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 05-29-2006, 01:52 PM   #6 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
My 90 Camry uses ATF for the power steering system. I had a leak also and used a brand that had a rubber conditioner additive. That seems to have stopped the leak. You may luck out.
On the other hand. If yours uses ATF (automatic transmission fluid) and you have put in regular power steering fluid you may have damaged part of the system. Check your manual.
Kep
Old 05-30-2006, 09:06 AM   #7 (permalink)
Doctor J's Avatar
Gameroom cash: $261790
View Doctor J's Photo Gallery
On 87 to 91 Camry four cylinder there are common places in power steering system that have leaks:
pressure hose, pump-to-firewall;
pump body, rear plate o-ring.
Doctor J is offline   Reply With Quote
corolla power steering question kewl_chap Archived Corolla threads 1 11-20-2004 08:37 PM
Power steering pump?!?! Dainfamusgc Camry & Solara Lounge 4 08-08-2004 02:05 AM
Power Steering 86CRESSIDA86 General Discussion 8 01-31-2002 04:25 AM
