the GR2's are a stiffer than stock ride. but not as stiff as the tokico's. although the tokico's are what will giveyou more performance.
our car's are front wheel drive...if you put a larger front sway on it, more than likely you will experience more understeer than you had before because your car will be more like a solid block and it wont want to turn. The whiteline rear made a difference to me and having the strut tower bar is good enough.
That's what I needed to know..
Thanks man...
I think I might still go with the GR-2's, although, thanks for the info...
good thread cuz i wanna know about my suspension. im wondering if i put after market struts w/ stock springs would it ride stiffer? and pty camry...where'd u get ur stuff? it's hard for me to find stuff for the camry.
I'm out like a fat kid in dodge ball!
stiffer yes..but not by too much as the struts will make most of the ride difference while the springs usually just lower your car. Also if your struts are old they will probably blow faster if you have your car lowed on them due to the constant extra pressure. you can try the setup for a while but im sure you'll want to get new struts soon after. And if you love your car and plan to keep it for a long time, think about coilovers if you can afford them.
see the thing is mine r just flat out blown. the front ones make like hissing noises when i hit bumps and the back ones when i come off a speed bump it bounces like crazy. so would it help if i bought brand new stock springs and aftermarket struts? i dont really wanna lower it i just want a stiffer ride. i have a gen5 stock sway bar in the back but it made no difference so i want something better cuz my car handles horribly on turns.
toyota is known for a softer ride. anything OEM isnt going to give you a great handling capability.
Springs will last over 100K before they need replacing. Changing struts makes a huge difference. Perhaps you can go stick with your oem springs and get Tokios...that maybe a better choice for you. It's a waste of your money unless a pro says you need to change your springs if you're just gunna get oem ones again.
