Rear Panel Removal
I have a 2002 XLE, and am replacing the rear speakers. I've gone through Ray's Gen4 removal instructions and the Gen5 Repair Manual for instructions to access the rear speakers. I removed everything up to the rear panel, and can't remove it. The instruction say to pull the tray trim panel up - no problem,... then to to disengage the clips and claws - no go, it won't oull out. How do you disengage the claws in the rear near the glass? I've pulled straight out, and it doesn't release. Am I missing something? Is the rear window shade causing a problem? Thanks.
