so the PCV valve just pulls right out - pull straight upwards? is this right?
Of course, the end that attached to the hose I need to release the retainer clamp.
Be very careful when pulling it out - if the rubber grommet that holds it in is hard and brittle, you won't be able to put it back in without completely removing the old grommet and installing a new one.
It can be very tricky to get an old, brittle one out of the valve cover.
The PCV is located on the back valve cover it is on the passangers side and it is black whith a hose connected to it that goes to the intake manifold you only have to twist it a bit to get it out but you don't need any kind of tool. it costed me $ 3.99 at autozone. I think that it is worh the money if you are having a bad idle.
for an I4..it would be at the corner nearest the driver's seat on the vavle cover.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
Yup, just twist a bit. Thats what I did.. I was soooo scared of breaking it though.. In the end, i got a smidge fed up and pull the vice-grips and pulled that badboy outta there with no prob BE CAREFUL not to break it though
Anyone got any photo that shows where it is, I've searched the forum and google, but found nothing. Or maybe show me what the PCV valve looks like on Gen4 V6 camry. Thanks.
Also, do I need any tool to change it? Screwdriver, etc?
Bah..rang Toyota today, re: PCV hose....i need "overnight parts from Japan"....(well 3 weeks) hahaha...don't they keep any of this stuff in Australia!!
__________________ 1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
On a toyota that has been well maintained (meaning you have done proper oil changes) I wouldn't worry about replacing the PCV valve until 60k. I have done that on several of my Toyotas and even at 60k, the valve is working fine I just replace it then because I want to.
I've put over 500K combined miles on a Mazda and three Toyotas and have never seen a PCV valve go bad.
You have never seen one doesn't mean they don't exist.
It can go bad for many reasons.
When it's clogged, you won't feel it but you'll start getting oil leak, or get bad gas mileage.
