A/C Leak
Last year I got into a minor accident that put a hole through the condenser. I had a new condenser installed and all was fine, it was very very cold. I put on my A/C now, after a few months had passed since the condenser was installed and it wasn't cold at all. I took it in to my mechanic and it was missing a few pounds of Freon, so obviously there is a leak. He put this fluorescent dye into the system, refilled it with Freon and said to come back in a few days to check for a leak, since it was obviously a slow leak. How does this fluorescent dye work AND do you think this new leak could be caused because fittings for the condenser may not have been tightened sufficiently or that the rubber O-rings on these fittings have worn out? The original Freon lasted for 10 years, and never had to be charged even once...a testament to the OE Toyota quality. I hope this problem will get resolved shortly
