cost to change the suspension - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-28-2006, 11:53 PM   #1 (permalink)
View kdyj's Photo Gallery
4th Generation cost to change the suspension
Hi:
My rear tires are deformed every year, and I have to replace the new one every year.
Is that my suspension problem and need alignment as well?
How much does it cost to change a new suspension for 98 4 cylinders?
Thanks for any help and information..
Kdyj.....
kdyj is offline   Reply With Quote
Old 05-29-2006, 12:11 AM   #2 (permalink)
View thoughthard's Photo Gallery
Please describe the tire wear, or post a pic of the wear.
thoughthard is offline   Reply With Quote
Old 05-29-2006, 12:12 AM   #3 (permalink)
bitch please
DarkMastyr's Avatar
View DarkMastyr's Photo Gallery
Suspension parts... I'd say at $600+ if you're looking to change struts, springs, and miscellaneous (strut mounts, boots, etc.), or you can spend over $1k-$2k on a coilover suspension. Labor... you can install yourself with a spring compressor from a hardware store, or pay someone ~$200-300 to install it for you (that's the high end for labor costs I think, if you go to some joe schmoe mechanic who wants to charge you up the arse). Alignment is usually ~$70-$80.
If your tires are messed up, get an alignment first. It's likely your suspension isn't the main factor. Also make sure that when you get new ones that they are properly balanced with the wheel.
1994 Camry 2.2L LE Auto
DarkMastyr is offline   Reply With Quote
Old 05-29-2006, 08:06 AM   #4 (permalink)
Camryologist
ptycamry's Avatar
View ptycamry's Photo Gallery
^^^^ what he said...
ptycamry is offline   Reply With Quote
Old 05-29-2006, 10:48 AM   #5 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Have suspesion checked when the alignment is being done. There may be conditions (damage and wear) that will not allow the alignment to be done properly.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Hajoca is online now   Reply With Quote
How anyone can change the traffic lights green Misctick Off Topic 35 06-06-2006 10:45 AM
Gen 3.5 Oil Change camryelaine 3rd & 4th Generation (1992–1996 & 1997–2001) 4 05-19-2006 07:23 AM
15K miles trans fluid change? Joe B Archived Corolla threads 3 04-25-2006 05:35 PM
Oil Change YYY Camry Camry & Solara Lounge 7 04-11-2006 08:26 AM
Cost of OEM water pump + labor skewe Camry & Solara Lounge 13 03-26-2006 05:38 PM
