Originally Posted by Nuke209
today, we changed the fuel filter, everything went fine and suddenly the car's shaking, the idle was kinda low, but the needle was shaking also....what's the problem?
The fuel flow rate is flowing at a different rate. Which means the ECU has to slowly calculate and reconfig the timing.
Check the filter one more time just to make sure. Drive for a week and the ECU should adjust accordingly.
Its the same effect if you disconnect a car bettery then put it back in, the ECU is resetted and the car idle's kinda off for about a week. Dare ya to try on a friends car.
but, I could be wrong. Good luck though.
