Fan Constant Run connection - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-30-2006, 11:19 PM   #1 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
While hunting around at the back of the engine with the wiring loom, i found this little plug. It has 2 wires, (Black w/ red stripes) and a cap on it to "connect" the two together. After disconnecting this little cap, i found that when the key is turned to "Ignition/Run", both thermo fans stay constantly on. Replacing the cap returns the fans to normal "thermo" operation.
Heres a pic of the little plug:
So yeah, just a FYI and also a question as to why this would be needed? What purpose would it serve? Really hot weather?
Cheers.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 05-31-2006, 02:31 PM   #2 (permalink)
View marc780's Photo Gallery
Because you dont always need the fans to run. At highway speed in cool weather, for example, when there is lots of airflow through the radiator and running the fans is sometimes a waste of power etc. and could overcool the engine and lower your mileage. So its connected to a thermoswitch.
Old 05-31-2006, 03:24 PM   #3 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
also referred to as fan relay! If your theromostat is stuck to close position, uncaping (unhooking) this relay would make the fans stay on constantly! In the middle-east for the first 1000kms the dealerships unhook (uncap as per your teminology) this to prevent heat-soak, to keep the engine temps lower for new cars until they are broken in well.
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 05-31-2006, 04:33 PM   #4 (permalink)
VeeZed
I see! Thanks for the replies.
Electric Fan Brando8844 T-100 3 01-02-2006 06:36 AM
Condenser fan not working (93 Camry LE V4) hemant 3rd & 4th Generation (1992–1996 & 1997–2001) 10 12-29-2005 02:35 PM
radiator and ac fan not spinning rizzo Camry & Solara Lounge 6 05-11-2004 02:02 PM
90 Camry A/C & Cooling fan run continuously Dan Thompson General Discussion 0 01-23-2003 01:45 PM
