Numbers on rod caps? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-31-2006, 12:59 AM   #1 (permalink)
View The Black Camry's Photo Gallery
What exactly do the stamped numbers mean on the rod caps. I know it has to do with the bearing but what exactly
The Black Camry is offline   Reply With Quote
Old 05-31-2006, 02:19 AM   #2 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
http://www.ae92gts.com/ae92gts_engine_bearings.html
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 06-01-2006, 08:22 PM   #3 (permalink)
View marc780's Photo Gallery
What jet speed said, and thats news to me. But if the numbers are 1, 2, 3, or 4 etc. they tell you what cap goes with what rod. Because they have to go back on the same rod they came off off, because they are machined to match each other.
In other words, mixing them up is a bad bad thing to do and might cause engine problems i.e. your rod cap breaks loose and the cap blows a hole through your oil pan (which i saw happen on a Ford escort - the aftermath rather).
Old 06-01-2006, 10:50 PM   #4 (permalink)
VeeZed
You will get excessive rod knock and wear on the main bearings if they are mixed up.
Always keep them paired up correctly..same goes for cam shims/valves/buckets/girdles.
Old 06-02-2006, 12:30 AM   #5 (permalink)
Thanks I kind of figured! And the numbers on the ROD CAPS only go to 3! ( different bearing sizes. The main caps are the ones that have 1-4. But those numbers are only good If you plan on putting back the oem bearings. IF you have machine work then all that changes.
Steering Rod Recall rivethed 89-95 Toyota Pickup/Hilux 27 12-04-2008 11:37 PM
07 Camry V6 part numbers so40 5th & 6th Generation (2002-2006 & 2007-2011) 4 05-08-2006 05:04 PM
tie rod Q+A Redlyne_mr2 Hardcore Tech and Competition 5 01-12-2006 12:13 AM
Avalon or Camry OEM Center caps mandyfig 1st Generation (1995-1999) 3 02-13-2005 02:05 PM
rod bolts? 2drcam Camry & Solara Lounge 3 08-08-2004 01:21 PM
