--click--click---start--? ecu problem? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-31-2006, 08:36 AM   #1 (permalink)
View sanfelice's Photo Gallery
My 94 V6 is doing odd things when starting. It will click once, twice or three times, and then start. I had this problem a couple weeks ago and replaced the battery (not brandy new, but with a good charge) and that solved the problem up until now. At its worst a couple weeks ago, it would not start at all toward the end, which seemed like a dead battery. I can always buy a brand new batter, but do not want to waste $80 if it is not the battery.
What could be going on? Is there an ECU that is going bad or is there something simpler? Any ideas as to what is going on?
Thanks!
sanfelice is offline   Reply With Quote
Old 05-31-2006, 08:51 AM   #2 (permalink)
93 240sx SR Hatch
DAMON's Avatar
iTrader Score: 36 reviews
View DAMON's Photo Gallery
my car had a similar issue last winter that turned out to be the starter contacts. are you saying that you go to start it and when you turn the key it just clicks for a couple tries and then starts? if so Im thinking its gotta be those starter contacts
94 Camry (Beater) 99 Solara (Totaled) 93 240SX (Current)
DAMON is offline   Reply With Quote
Old 05-31-2006, 09:33 AM   #3 (permalink)
yup, that is exactly what is happening. i replaced the negative battery contact as that seemed to be loose, but obviously it did not solve the problem. hmmm. are the starter contacts difficult to access?
Old 05-31-2006, 09:41 AM   #4 (permalink)
View TeamRedLinePerf's Photo Gallery
Sounds like either your starter contacts need to be cleaned, you have a loose ground somewhere or your starter is starting to fail. If its the latter you can have it tested at Autozone for free and they'll let you know what condition the starter is in.
Luis
TeamRedLinePerf is offline   Reply With Quote
Old 05-31-2006, 10:24 AM   #5 (permalink)
Dave's
Gameroom cash: $122050
View Dave's's Photo Gallery
Somewhere there's a great thread with pics on replacing the contacts.
Dave's is offline   Reply With Quote
Old 05-31-2006, 10:31 AM   #6 (permalink)
i'll search for it. do you know if it was for a GenIII?
thanks
Old 05-31-2006, 10:38 AM   #7 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $910327
iTrader Score: 59 reviews
Agree! starter contacts. Had same prob with a 96 sedan...dealer repaired,wasn't very expensive!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 05-31-2006, 01:44 PM   #8 (permalink)
View marc780's Photo Gallery
Yeah where do you get the starter contacts? And what about the bearings, do those often nedd be changed too?
BTW i was wondering if anyone bothered to rebuild their own alternator. Seems like a job that is not so easy because you need a press , etc. But has anyone done it?
Old 05-31-2006, 03:01 PM   #9 (permalink)
Gameroom cash: $304355
Here's the link for the starter solenoid contact replacement:
http://www.automotiveforums.com/vbul...d.php?t=166530
The dealer sells the replacement contacts. Just be sure to call ahead to see if your dealer carries them and also to bring the contacts from your starter with you.
Mike
Mike Gerber is online now   Reply With Quote
Old 05-31-2006, 03:40 PM   #10 (permalink)
93 240sx SR Hatch
DAMON's Avatar
yeah I just had the dealer do it for me because i needed a timing belt and water pump anyway, it wasnt too expensive, itd be a ton cheaper if you did it yourself im sure
Old 06-01-2006, 04:17 AM   #11 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Send a PM to Tercel GTS. He rebuilds starters & alternators.
Starter:
Repair your own STARTER
Alternator:
Rebuild your own alternator
"Skoolin' the unlearned!"
Old 06-06-2006, 04:22 PM   #12 (permalink)
REAPER STRAIN's Avatar
View REAPER STRAIN's Photo Gallery
When mine did this it was the battery. To be sure take it to autozone or advance auto parts for a free battery test. Then check all your connectors. Good luck
REAPER STRAIN is offline   Reply With Quote
94 corolla 1.6 start problem ranger Archived Corolla threads 1 02-03-2005 12:49 PM
Problem 89 corrola, will not start CamryDX Archived Corolla threads 4 07-10-2003 12:54 AM
If car doesn't start... Whats the problem? BoogieMan Camry & Solara Lounge 6 03-23-2003 01:43 PM
Need help asap. No start problem. kieran1094 Archived Corolla threads 2 07-28-2002 10:48 PM
Solara ECU Problem - How to reset?? BamBamT Solara 13 01-30-2002 10:22 PM
