Turn signal blinking fast - most of the time - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-01-2006, 09:28 PM   #1 (permalink)
View fineart's Photo Gallery
Hi
My 1998 Camry has a right turn signal that blinks very fast - most of the time. Rarely it suddenly behaves itself and blinks normally, but that doesn;t last long!
I want to check the bulb in the front especially, but I cannot figure out how to access it. It seems like it is sealed in there (bad design imo).
Can someone help me figure out how to change thee bulbs, and/or figure out why it blinks so fast? When the front rt bulb is blinking (fast) it is a little tiny faint light, so there is *some* light. So if it is a bad bulb I can't figure out why it would be working a 'little' bit and not just not at all.
Sort of like being partially pregnant
Thanks
Kari
fineart is offline   Reply With Quote
Old 06-01-2006, 09:32 PM   #2 (permalink)
View foompla's Photo Gallery
replace the bulb if there are no screws, then it just pops out.
foompla is offline   Reply With Quote
Old 06-01-2006, 10:17 PM   #3 (permalink)
Thanks for the reply
It is the right front blinker bulb, looks to be sealed in a platic casing. How does one make it pop out? There are no screws to lift off the plastic cover and no way (it seems) to get at it from the engine compartment. How to I gain access to the bulb?
Thanks again!
Kari
Old 06-01-2006, 10:24 PM   #4 (permalink)
Gameroom cash: $284230
View LE05's Photo Gallery
the reason its blinking fast is because its on its way out, or blown already. to replace the bulb (i think, i don't have a 98 camry, but most cars are the same), you need to twist the socket/connector out of the housing. that'll give you access to the bulb to change it.
LE05 is online now   Reply With Quote
Old 06-01-2006, 10:35 PM   #5 (permalink)
Thanks for your reply.
When I lift up the hood, I see the socket gizmo for the *headlight* but the turnsignal buld is completely obscured by a metal shelf of some sort. There are no screws on the outside, and nothing but metal (it seems) blocking access from the inside. Do I have to drill a hole in the metal the bulb is hiding behind first?
You'd think they would have made it easier to get to.
Thanks Again
Kari
Old 06-02-2006, 03:11 AM   #6 (permalink)
Gameroom cash: $304355
If you have the owner's manual, it should show you how to access the bulb.
Mike
Old 06-02-2006, 03:52 AM   #7 (permalink)
Home of the Demon Cam
CamryOwner98's Avatar
View CamryOwner98's Photo Gallery
yes, check your manual, it's really simple to do.
If you don't have the manual:
After you open your hood, look at how the turn signal housing is connected to the car, there is a plastic (black) screw-like tab that you can pry off using a screwdriver. Using a cloth, put over the screwdriver and gently pry in between the turn signal and the headlight housing. Once loose enough, pull it forward to slide out the turn signal housing.
Self explanitory after that, you'll see the wiring and socket connected to the turn signal housing.
PS: refer the this pic to find the screw-like tab.
http://cgi.ebay.ca/toyota-CAMRY-97-9...QQcmdZViewItem
The long plastic piece on top of the housing (where is hole is seen). That's the location of the tab. Pop that off first.
Mods:
HID TL Bi-Xenon Projectors~Auxillary Bosch Mini Projectors~
Superflux LED Tails~
Euro guages~Halogen Fogs~
CamryOwner98 is offline   Reply With Quote
Old 06-02-2006, 08:31 AM   #8 (permalink)
View Camry005man's Photo Gallery
I think you need to take the whole headlight off, then you will be able to slide the turnsignal out.
Camry005man is offline   Reply With Quote
Old 06-02-2006, 11:02 AM   #9 (permalink)
Thanks so much, I got rhe old one out and the new one in.
The plastic tab thing is kind of dumb. Was the budget too tight for one more screw? For anybody else, behind the turn signal housing there is a black phlange that hooks to the frame where the turn signal bulb housing meets the metal of the car. You then get hold of that black plastic bracket which holds the housing in place and work it forward until the lip of the phlange is dislodged, then the thing comes right out.
Looks like the new bulb was all I needed.
Thanks again everyone for your helpful tips!
Kari
Turn signal stalk problem ddmba Camry & Solara Lounge 2 07-06-2005 10:30 AM
Check Engine Light Problem Aaagogo Celica Forum 7 09-02-2004 05:46 PM
Help turn signal happyvan Camry & Solara Lounge 1 06-09-2004 03:29 AM
Update on progression on the Wraith!!!! 56K warning Wraith Hardcore Tech and Competition 72 05-08-2004 03:06 AM
could you get away with it bondobondo General Discussion 46 07-06-2002 12:00 PM
