Power steering fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-03-2006, 06:46 PM   #1 (permalink)
View James100's Photo Gallery
A friend of mine has a '98 Camry 2.2 with 100k and the PS fluid is black. Car is not here now. What is the original fluid, power steering fluid or ATF? What mileage does it usually get changed at? Looks like its due.
Thanks
James100 is offline   Reply With Quote
Old 06-03-2006, 07:27 PM   #2 (permalink)
The 6"4 Viking
Zandro's Avatar
View Zandro's Photo Gallery
ATF is the original fluid
Zandro`s 09 Hilux 3.0 D4-D SR+
Zandro is offline   Reply With Quote
Old 06-03-2006, 10:28 PM   #3 (permalink)
View marc780's Photo Gallery
Use a turkey baster
from the 99 cent store or wherever, and suck out this fluid. Add some fluid, run the engine a minute, shut off engine. Repeat til clean. Theres not a whole bunch of fluid in there like maybe a quart or two but i would buy 2 or 3 qts of new ATF fluid. I wouldnt use anything to attempt to flush it other than new fluid, this could create problems if you dump chemicals in there and they are not compatible with the seals or bearings etc.
This is bound to get tedious after a few minutes but IMO its the easiest way. If you are disconecting hoses, etc. you risk a leak and getting air in the system plus maybe a big mess, no big deal but its easy to avoid just by using the baster.
Old 06-03-2006, 10:39 PM   #4 (permalink)
Thanks for the reply.
Yes, I know the turkey baster methood from 99cent. In fact I invented it. There is a good pinned post about using a clear hose and barb to do a flush on it. I think I will do that this time since I just got the stuff for $4 tonight. Also you can use a bolt to block one end of the small hose if you look at this thread. Material was 3/8 ID clear hose, 3/8 barb and a bolt for $.25. Total about $4.
'93 Camry Power Steering Problem joeantispam 3rd & 4th Generation (1992–1996 & 1997–2001) 20 10-23-2011 07:34 PM
Power steering noise after flushing/changing the steering fluid Camry 2001 Mark22 3rd & 4th Generation (1992–1996 & 1997–2001) 1 12-26-2005 12:34 PM
how often do you change your power steering fluid? 01loadedLE Archived Corolla threads 5 09-20-2005 01:26 PM
Power Steering Checklist help blazin_azn MR2 Forum 14 06-13-2005 09:31 AM
dirty Power steering? hdsalinas Archived Corolla threads 0 05-30-2005 04:09 PM
