Oxygwn Sensor Bad(computer code: P1133)? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-03-2006, 06:56 PM   #1 (permalink)
View jliu66's Photo Gallery
Hi, everyone,
I have 1999 Camry LE (2.2liter). Last week, engine check light is on. I took it to the mechanic. The computer comes out with a code P1133. The following explanation is Oxygen sensor problem. The mechanic says it costs $3-400 to replace it.
Do you know computer code P1133 is Oxygen Sensor problem? Do you think spark plugs can cause the similar problem or engine check light on?
Normally, how much does it cost to replace one including labor? Where is the best place to buy one myself and install it myself?
Do you know what is the procedures to uninstall the old one and reinstall the new one?
Many thanks in advance.
John
jliu66 is offline   Reply With Quote
Old 06-04-2006, 12:53 PM   #2 (permalink)
Gameroom cash: $304355
Read the following link for the exact code description:
http://www.iequus.com/obd_def.asp
Your car has 2 O2 sensors. There is a front one identified as bank 1-sensor 1 (it's in front of the converter) and a rear one identified as bank 1-sensor 2 (it's in back of the converter). Is your mechanic going to replace both of them? The OEM Toyota sensors run about $135 each at the dealer. The front one should take about 10 minutes to replace; the rear one about 30-45 minutes. I would say an independent mechanic should charge about 1 hour of labor to replace both sensors.
You can buy aftermarker sensors yourself at just about any auto parts stores and install them. Some of the aftermarket ones require you to cut the 4 wires off the OEM connector and splice the 4 wires of the new sensor back on to it. You will need a special O2 sensor socket (about $10-$15) or an open end 22MM wrench. The front one is located under the hood and is easy to spot. It should be obvious how to remove and reinstall that one. The rear one is under the car in the exhaust pipe after the converter, and it's electrical connector is under the driver's seat, and is accessible by pulling the carpet to the side where the floor vent is for the rear seat passengers. For the rear one you disconnect the electrical connector inside the car and push it through the floor of the car toward the outside. Then you can unscrew the sensor itself from the exhaust. I recommend tying a long piece of heavy string to the connector before pushing it through the bottom. Then, once out, you can tie the new connector to the string and pull it back in to the passenger compartment of the car.
Mike
Old 06-04-2006, 05:38 PM   #3 (permalink)
I will try it and thanks, Mike.
Mike,
Thanks so much. I have it a try.
Many thanks again.
Best,
John
Old 06-05-2006, 08:08 AM   #4 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140895
i just got a denso oxygen sensor from www.oxygensensors.com for a good price. much cheaper than a dealer. they also have generics if you want to save a couple of bucks and do some splicing.
ghettosled is online now   Reply With Quote
Old 06-05-2006, 08:50 AM   #5 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $280492
View csaxon's Photo Gallery
P1133 is for a California spec car.
If you ran your car out of gas or close to it, then that sometimes triggers the p1133.
TSB EG009-99 mentions an "improved A/F Sensor" part#89467-33011 to replace the old 89467-33010
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 06-05-2006, 10:40 PM   #6 (permalink)
Originally Posted by jliu66
Mike,
Many thanks again.
Best,
John
You're welcome.
Mike
Toyota Engine code vivian General Discussion 22 12-27-2008 01:16 AM
why am i getting code 52 eyz closd MR2 Forum 7 01-10-2006 08:36 AM
Generic Error code P1133 on '98 Camry lunachk 3rd & 4th Generation (1992–1996 & 1997–2001) 8 09-09-2005 01:09 PM
Check Engine light Code 25 & 26, please HELP!! xaznxeclipsex MR2 Forum 0 06-01-2004 08:46 PM
ecu trouble code Nx2k Archived Corolla threads 1 02-12-2003 06:36 PM
