Headlight Power Supply???? HELP! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-03-2006, 09:02 PM   #1 (permalink)
View 99Camry99's Photo Gallery
4th Generation Headlight Power Supply???? HELP!
I bought a set of aftermarket gauges for my 99 Camry. I need to hook up the power to the headlight power supply. Where do I find it and how do I do it? Do I need to splice anything? I tried hooking it up to the back of the stock gauge cluster but that didn't work. Can I get some help on this? Thanks!
99Camry99 is offline   Reply With Quote
Old 06-03-2006, 11:53 PM   #2 (permalink)
camry "durabilty" tester
View brownyy's Photo Gallery
i needed to run another circuit thingy form my car when the ignition was on... all i did was read the fuse book and find which one powered the intrament (spelling is shot i'm hungover) cluster... (there's a few by memory)
turned ignition on, instraments lite up, pull fuse they turn off etc etc... make sure you check with side of fuse to splice into... (safe side so fuse will protected your new gauge)
good luck...
brownyy is offline   Reply With Quote
Old 06-05-2006, 05:21 PM   #3 (permalink)
View marc780's Photo Gallery
Don't cut your wires, there's no need! Just find the headlight fuse and get one of thes fuse taps. You can get these fuse taps all over thee place but heres the place i stole the image from.
http://www.wirthco.com/product_info....2cea3d1581d344
[UPDATED w/ more photos!!] Gen 3 new cystral headlight housing arrived (w/ pics) bowen 3rd & 4th Generation (1992–1996 & 1997–2001) 62 10-09-2006 11:01 PM
Seperating 02-04 Camry headlights italia490 5th & 6th Generation (2002-2006 & 2007-2011) 1 12-17-2004 12:18 PM
my driver side headlight is really crooked TypeZer0 Camry & Solara Lounge 6 09-09-2003 09:15 AM
