Goodridge SS Brake line install tip - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-03-2006, 09:56 PM   #1 (permalink)
Poman's Avatar
View Poman's Photo Gallery
This should apply to Camry V6 owners:
Found out that my front cross drilled/slotted rotors were warped which caused my pulsation of the steering wheel when braking. So I decided to replace everything myself, Brembo rotors, Hawk street pads, and Goodridge SS brake lines for all 4 wheels.
Replacing rotors and pads was easy, I did ran into some problems with the rear pads fitting but it was my fault with the sliding pin for the lower bolt. I didn't know it moves!
Now for the Goodridge SS brake lines, if anyone of you wants to replace it yourself, do it because it's pretty easy. I've seen many posts here with people hesitating to install it. If you have Haynes Manual, follow it mostly, but here' the tip I have when I replaced mine today:
- In Haynes manual, they want you to remove the brake line fitting from the frame bracket, then remove the U clip, Don't follow it! I followed that and I almost screwed my fitting since somehow the fitting didn't have enough room to move up and bent it a little. I had a hard time bending it back so I could screw it back into the new line. So what you want to do is unscrew the fitting using the flare-nut wrench (must have) and don't unscrew it all the way, just loose it a little. Next remove the U clip at this time, then unscrew the fitting all the way. That's the hard part. The bolt at the caliper was easy, removed and reinstalled it with the new bolt and crush washers provided and tight everything back on with the new SS line. Bleed the brake and that's it.
Just a little info for ya! In case I forgot how it was done in the future I can always find this post here to remind myself! Have fun!
PomaN
99 Original Solara SLE SC@5lb - Original (yup) TRD suspension and muffler
Poman is offline   Reply With Quote
Fuel line in rear leaking, need to replace - help please? Neurowiz Supra Forum 3 11-09-2004 10:16 AM
SW20 brakes for the do-it-yourselfer ... KAOS MR2 Forum 11 09-18-2004 01:21 AM
Does anyone install an exhaust tip on your 04 4Runner? njchen24 4Runner Lounge 2 08-03-2004 09:26 AM
Need a ready to install brake/fuel line kit for my camry- anyone sell this? bennington28 Hardcore Tech and Competition 2 07-28-2004 12:16 AM
Technafit SS Brake Lines: impressions, problems brink Hardcore Tech and Competition 5 04-28-2004 01:54 PM
