Hood cable issues - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-03-2003, 10:20 PM   #1 (permalink)
87Camry5Speed
Guest
Posts: n/a
View 87Camry5Speed's Photo Gallery
Angry Hood cable issues
Alright, here's the deal: After my unfortunate accident almost two months ago, all was reassembled and well.... except the hood cable. The end of the cable, where it hooks up to the spring on the hinge, broke clean off (wait... we kinda HAD to break it off because it was the only way to get under the hood to see where the anti-freeze was leaking from.) Well, I managed to get the old one out, but I just about flipped out trying to get the new one in. For the record, a pseudo-cable has been jerry-rigged out of a metal coat hanger for now. Works fine. But having a rusting white coat hanger sticking out between the headlight and header panel = gay. I tried to route the cable in through the fender to no avail. I can't see where the old one ran into the dash, it's somewhere behind the fuse box. Help! Since the hanger method is serving me well for now, I'm redoing the cable when it gets warm again . (#@!*^% Northeast winters!) How am I going to get the new cable in?!?!?!?!
Old 03-03-2003, 11:35 PM   #2 (permalink)
View DIRTBIKEZ's Photo Gallery
You can get some hoodpins like spills1969 .
'91 Camry DX
2.0L 3SFE Auto
R.I.P.
DIRTBIKEZ is offline   Reply With Quote
Old 03-04-2003, 10:51 AM   #3 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
get that drill out, its time for some hood pins!!!
-Nick
Nick is offline   Reply With Quote
Old 03-04-2003, 05:37 PM   #4 (permalink)
87Camry5Speed
Guest
Posts: n/a
Hood pins... now that's a kick-ass idea! But since I have the cable already I might as well try to put it in. Nonetheless, I'm intrigued; how much is the average set of pins? Perhaps I'll consider it... 4 pins across the hood NASCAR style is cool and rice overkill at the same time!
Old 03-04-2003, 06:26 PM   #5 (permalink)
Lives For The Curves
View nort0188's Photo Gallery
UP Racing has hood pins. $25 USD for a pair, and I believe they're made by Sparco.
If torque actually won races, wouldn't we all be driving diesels?
nort0188 is offline   Reply With Quote
Old 03-04-2003, 07:57 PM   #6 (permalink)
View crazy_camry's Photo Gallery
with hood pins though doesn't it mean that anyone can pop your hood, there's no locking mechanism, is there?
crazy_camry is offline   Reply With Quote
Old 03-05-2003, 03:08 AM   #7 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $308075
You should have watched how it went through the fender when you pulled it out the first time...
Anyway, I think I can get you started on your way to finding how the cable goes into the car. The cable runs from the front latch, behind the headlight and under the intake tube that runs under the fuse box. If you remove the battery, you should be able to access all you need to in that area. From there, it goes into the fender through the hole right next to the airbox. If you jack up the driver's side of the car and take off the fender liner, you can then see where it goes to the footwell. There are a few grommet there, one of which is meant for the cable. Inside the car, you can take off a trim panel or two, and it should all be visible. Good luck. Post back if you have any questions... (and choose to go back to stock instead of hood pins!)
-Charlie
white90dx is online now   Reply With Quote
Old 03-05-2003, 08:09 AM   #8 (permalink)
87Camry5Speed
Guest
Posts: n/a
I decided I'm going back to stock. Too many security issues with the pins... even though they do look good; Charlie, I know where the cable's going under the hood, it's just in the fender and in the car that gets me. Whoever would have thought that a simple hood cable install could be such a %$!(&? Anyway I guess I will have to drop the inner fender- should be easy though. The car had been in another light front-end whack before I got it and the fender itself is only held on by like 4 bolts. I'm still looking for the screws holding the inner fender in place... I wonder if there even are any left in there! Scares me every time I go through the carwash so that's something else I gots to fix. Thanks all for your help.
Old 03-05-2003, 01:18 PM   #9 (permalink)
white90dx's Avatar
Once you get the fender liner out of the way, it should be pretty easy to route things. Some of the fasteners are a bit tough, but you'll get it. I've run 0 gauge power wire on through there, so I'm sure there is plenty of room!
If you are talking about missing the inner fender cover (the plastic thing that goes near the tranny), don't worry about it. There are no electrical parts down there or anything. I have been running without that little trim piece for years.
-Charlie
Old 03-15-2003, 09:37 PM   #10 (permalink)
87Camry5Speed
Guest
Posts: n/a
Finally got a break in the weather today and dropped the new cable in. I dropped the inner fender as white90dx suggested (had no idea there were like 5 bolts hidden by the tire! So THAT's why the tire had to come off ) The job took a couple of hours, and toward the end I was losing daylight fast; this was when a) I couldn't get the hinge assembly to line up right with the bolt holes, and b) the return spring raised hell. Once I got the cable through the orange rubber insulator in the fender (where the electrical wires are, as well) it practically routed itself. No disassembly of the dash was required. The job wasn't too bad, but not something I'd ever want to do again. Thanks again white90dx for your help.
