A/C question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-04-2006, 05:08 PM   #1 (permalink)
View Camry005man's Photo Gallery
A/C question
I notice waste water comes out of the hose when I use A/C is normal, but when I do not use A/C, water still comes out. Is it normal?
Camry005man is offline   Reply With Quote
Old 06-05-2006, 05:11 PM   #2 (permalink)
View marc780's Photo Gallery
As long as this water is clear water with no coolant, i think it's normal, because what else could be making the water? Perhaps the hose is kinked or clogged up some and you should blow it out or change it
Old 06-10-2006, 03:37 AM   #3 (permalink)
View toyomoho's Photo Gallery
What hose? When the A/C is working, water can condense on the evaporator and run out the bottom of the car through a hose. If you park the car, you may see a puddle (sometimes large) form under the car near the engine. This is normal. Try not running the A/C for a few days then see if water is still running out.
A/C and general maintenance question t3ch Supra Forum 4 10-17-2006 07:14 PM
A/C Light Flashes - AC Doesnt work jrock80 Camry & Solara Lounge 24 06-19-2006 11:48 AM
A/C Question - Low Pressure Port noteworthyone General Discussion 2 06-15-2005 11:42 AM
A question regarding A/C TOYOTA CARS Camry & Solara Lounge 14 06-10-2005 04:00 PM
'89 4 cyl camry.. O/D lights blink off and on as well as A/C Bobby C 01TA 1st & 2nd Generation (1983–1986 & 1987-1991) 1 06-09-2004 03:21 PM
