Water Coolant? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-05-2006, 07:53 AM   #1 (permalink)
megamac83's Avatar
View megamac83's Photo Gallery
Water Coolant?
Hey guys quick question, now that we are in the days of summer, I just wanted to know what people thought of running a 80 % water and 20 % antifreeze mix? or even greater percentage of water? has anybody done it what were the gains with better cooling? what are the down sides?
megamac83 is offline   Reply With Quote
Old 06-05-2006, 08:09 AM   #2 (permalink)
View Grayguy's Photo Gallery
I used to run 100% water in my truck during the summer, but that's only because it had a tendency to over heat and piss antifreeze everywhere and I got sick of paying for it. It did stop overheating while running the water, but I can't say that that's better, because at the same time I got a new fan shroud.
I'm not sure why more water would make is cool better. What's your theory there? Also, no matter what you do, switch it back to "normal" before it even gets close to freezing temperatures out. Unless of course you enjoy cracked blocks.
Grayguy is offline   Reply With Quote
Old 06-05-2006, 08:37 AM   #3 (permalink)
Dave's
Gameroom cash: $122050
View Dave's's Photo Gallery
Have things changed? This old guy was always taught that the best mix was 60/40 AF/water. (actually more like 55/45 but 60/40 is easier and close enough.) 100% antifreeze will freeze more quickly than a mix. It also doesn't cool as well I think. So unless things have changed, go with 60/40.
Dave's is offline   Reply With Quote
Old 06-05-2006, 09:06 AM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
if it's warm, there's no reason you can't run mostly water instead of the usual recommended 50/50 mix. But by the same token, unless your car is overheating, there won't really be a great benefit for doing so either though
antifreeze does as it's name implies by preventing your coolant mixture from freezing, but it also inhibits rust and other damaging contaminents in water to your cooling system, so running pure water isn't a really good idea either
but in terms of cooling, water can absorb the most heat
HaHa
Old 06-05-2006, 11:41 AM   #5 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
i run waterwetter and 75/25 water/coolant my car stays cool... the down side is @ night when it's cool takes a long time to warm up and if i drive on the freeway my temp guage goes down below the middle mark
Old 06-05-2006, 11:54 AM   #6 (permalink)
Gameroom cash: $926800
View ASG14's Photo Gallery
I'm running 100% water right now (Distilled water, not tap). I tried it after my friend told me he always does it in the summer. I've nituced the fans go on a lot less.
Water cools better then Antifreeze (but also has a lower boiling point).
5 Lug Corolla WHAT?
Old 06-05-2006, 12:30 PM   #7 (permalink)
View PhantomZX's Photo Gallery
I stand corrected...this statement is correct...
The main purpose of antifreeze is to prevent the water from turning to ice in cold temperatures (duh). Another important role it has is to lubricate the cooling system.
But, you were correct in saying that it doesn't cool as well as water, that's why it gets mixed rather than run at 100% concentration.
I've seen 80% water, 20% antifreeze used in cars during summer, and that won't be a problem if you change the coolant more frequently than you would with 50/50 mix.
PhantomZX is offline   Reply With Quote
Old 06-05-2006, 04:52 PM   #8 (permalink)
View marc780's Photo Gallery
I'd say that to me, for my cars maybe it is best to use what toyota says and i dont wanna get creative
Old 06-05-2006, 10:53 PM   #9 (permalink)
Gameroom cash: $304355
"Another important role it has is to lubricate the cooling system."
Absolutely correct. Antifreeze has lubricants that help lubricate the water pump.
"I'd say that to me, for my cars maybe it is best to use what toyota says and i dont wanna get creative."
I agree totally with Marc's statement. Why would you want to run mostly water? A 50/50 mixture of antifreeze and water has worked for a long time. If you are having problems with your cooling system look for the cause and correct it; don't try to reinvent the wheel.
Mike
Old 06-06-2006, 01:47 AM   #10 (permalink)
Dave's
What I found shows 100% ethylene glycol freezes at 10 degrees F while mixed 60/40 the freeze point becomes -55 degrees F. So it's possible to have the system freeze with 100% EG here in OK and most parts north. But it showed 70/30 as the best mix at <-60 degrees and a slightly higher boiling point as well. So maybe we both need to check our statements better in the future. And yes, here are lubricants added plus anti-rust additives. So, I would say stick with a mix. EDITED
Old 06-06-2006, 01:52 AM   #11 (permalink)
PICKLE GANGSTER
Rdizzle's Avatar
iTrader Score: 6 reviews
View Rdizzle's Photo Gallery
I agree with Atobe. I run water wetter in the summer and no matter how hot it is my temp stays down. Plus it has all the benifits of anti-freeze like rust inhibitors. Just be sure to change back in cold weather.
Originally Posted by DarkMastyr View Post
Is it just me, or has TN just become this massive gay fest? It's like you can't avoid the hot gayness in every thread.
[U]
http://www.cardomain.com/ride/398065...ry-le-coupe-2d
Rdizzle is offline   Reply With Quote
Old 06-06-2006, 01:54 AM   #12 (permalink)
MOUTH SLAP!
Your Uncle Moe's Avatar
View Your Uncle Moe's Photo Gallery
Leave the mixture the same and just add Waterwater. Its amazing. Plus Cams dont really have an overheating problem.
96 Camry V6 LE & 90 Eagle Talon TSI (AWD TURBO)
"Love is all you need to know and all you need to know is love is all you need to know."
Your Uncle Moe is offline   Reply With Quote
Old 06-06-2006, 03:05 AM   #13 (permalink)
i dont know anything about water wetter even though it sounds like a great idea in hot weather. So i did a search and this guy who says he is an expert wrote some things about it if anyone wants to know.
http://e30m3performance.com/myths/mo...ter_wetter.htm
Old 06-06-2006, 08:47 AM   #14 (permalink)
Absolutely untrue? So I looked it up. What I found shows 100% ethylene glycol freezes at 10 degrees F while mixed 60/40 the freeze point becomes -55 degrees F. So it's possible to have the system freeze with 100% EG here in OK and most parts north. But it showed 70/30 as the best mix at <-60 degrees and a slightly higher boiling point as well. So maybe we both need to check our statements better in the future. And yes, here are lubricants added plus anti-rust additives. So, I would say stick with a mix.
I guess I heard wrong before...I edited my original post
Old 06-07-2006, 02:31 PM   #15 (permalink)
megamac83's Avatar
thanks guys for your thoughts!!!
Gen 3 I4 Radiator Change/ Thermostat Change RningOnFumes 3rd & 4th Generation (1992–1996 & 1997–2001) 54 10-22-2011 02:35 PM
The Free Mod Series: Part VII Cheap Water Injection Toysrme Camry & Solara Lounge 17 05-26-2010 02:13 PM
Echo 2000 check engine light Raistlin Yaris, Vitz and Echo Forum 19 03-26-2007 05:33 PM
using only water as engine coolant chesstompowell Camry & Solara Lounge 17 03-04-2006 08:23 AM
Brand of Coolant stir_fry_boy Camry & Solara Lounge 51 01-12-2006 10:45 AM
