3.0 V6 Crank pulley bolt removal suggestions? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-05-2006, 02:57 PM   #1 (permalink)
View Robar's Photo Gallery
Hello - any suggestions for removing the crank pulley bolt without a special tool?
Having a very hard time with my breaker bar and socket. Thinking about an extension to the ground, and turn the motor over w/the key and break it loose. I have heard of this being done before.
Any other ideas welcome.
Can you pull the pulley with a standard puller?
Robar is offline   Reply With Quote
Old 06-05-2006, 04:26 PM   #2 (permalink)
View marc780's Photo Gallery
The old bump- the- starter trick, a lotta people have posts on this but its simple - put your breaker bar against something solid and bump the starter. DISABLE THe engine first -
as for the pulley it's probably better NOT to use a 2 or 3 jaw puller or you might be buying a new pulley. - use a CS pulley puller. There are 2 or 4 threaded holes in the pulley to thread into.
On the 4 banger if you had one, " there are pulley removal Points".
The tool you will wantto use should work like this toyota "SST"
And it doesnt matter whose puller you use, but when you do you will remove the CS pulley like this:
so my tensioner pulley bolt broke 98rolla Archived Corolla threads 3 06-01-2006 04:05 PM
Unorthodox crank pulley problem - help!!! fox_prime Camry & Solara Lounge 6 06-22-2005 01:22 PM
Can't break crank bolt loose. lafave General Discussion 7 02-16-2005 09:00 AM
Help me with correct belt size- underdrive crank pulley for 5SFE cman2000 3rd & 4th Generation (1992–1996 & 1997–2001) 13 01-24-2005 09:05 PM
Crank Pully Removal Problem...Need Advice corollamax Camry & Solara Lounge 6 10-10-2002 08:31 PM
