Tapping into the Electrical System - Don't cut your wires! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-05-2006, 05:26 PM   #1 (permalink)
View marc780's Photo Gallery
There's been alot of posts by people who needed to hook up accesorys like gauge lights and so on. And couldn't figure out how to tap into the power without mangling things. So i thought i'd post this make it easy for some poeple
http://www.wirthco.com/product_info....2cea3d1581d344
Old 06-05-2006, 06:48 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
wow...that's pretty neat actually....that's pretty much like the ghetto rig that I have used in the past where where I just slip the wire under the fuse and into the fuse box...lol
HaHa
Old 06-05-2006, 08:13 PM   #3 (permalink)
View shots76's Photo Gallery
It is nice. Just remember that will widen/loosen your fuse clip in the box. But that's the next person's problem when you sell your car.
shots76 is offline   Reply With Quote
Old 06-05-2006, 10:28 PM   #4 (permalink)
That's a valid concern, shots. But at work we use these on many fleet cars to power comm radios and lights, and i've yet to see a fuse loosen, even on a car with 100,000+ miles.
Old 06-06-2006, 05:15 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Thats better then wrapping a wire around a fuse, but its still ghetto rigging IMO.
Your adding onto a existing circuit and drawing more current from it.
Cutting wires is not a big deal, if you understand what your doing. I've done it plenty of times for alarm installs and other stuff.
"Skoolin' the unlearned!"
Old 06-06-2006, 06:40 AM   #6 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Rememer that splicing by soldering or crimp connector is the proper way. twisting wires and tapping is not going to last due to corrosion, mechanical vibration and strain.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 06-06-2006, 07:33 AM   #7 (permalink)
View ShadySport's Photo Gallery
why not use something like this?
http://www.tessco.com/products/displ....mc_id=froogle
ShadySport is offline   Reply With Quote
Old 06-06-2006, 07:42 AM   #8 (permalink)
93 240sx SR Hatch
DAMON's Avatar
iTrader Score: 36 reviews
View DAMON's Photo Gallery
cant you just slit the insulation on the wire you want to tap into, solder the accessory wire into it and then make sure it is re-insulated?
94 Camry (Beater) 99 Solara (Totaled) 93 240SX (Current)
DAMON is offline   Reply With Quote
Old 06-06-2006, 08:54 AM   #9 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
Originally Posted by ShadySport
ive used those, theyre great
WhiteRabbit is offline   Reply With Quote
Old 06-06-2006, 09:37 AM   #10 (permalink)
The Naive Voice of Reason
thapranksta's Avatar
View thapranksta's Photo Gallery
Gen5
Me too. It was a tight squeeze so I hope I don't have any problems later on. I was tapping into the ignition when I was installing my auto-dimming mirror in my Gen 5. They do stop the messy work.
Old Car: '03 Toyota Camry LE
New Car: '04 Black ES330 (Aftermarket sound/navigation system installed)
Always got something else in mind...
thapranksta is offline   Reply With Quote
Old 06-06-2006, 09:40 AM   #11 (permalink)
BTW, what is the guage of the wires running into the fuse box so I can use the exact size the next time I use those connectors?
Old 06-06-2006, 04:36 PM   #12 (permalink)
engineer in training
Gameroom cash: $145055
Thats a really neat idea! I think an even better one would be to hook that into a relay and connect the relay directly to the battery if you neeed to power a lot of gadgets. Use that as an easy ignition on switch ya know?
Old 06-06-2006, 11:44 PM   #13 (permalink)
Grenaded piston
88 LE's Avatar
I agree.
I always use crimp connectors, solder + heatshrink, or solder + electrical tape.
Yes, that works fine.
Old 06-07-2006, 03:38 AM   #14 (permalink)
Which is exactly what i have done on my '88 Nissan truck...i needed to fix the cigarette lighter (to use a solar battery charger) and i didnt want to muck around with it all day tracing circuits. So i ran black and red wires directly from the battery using crimp connectors and under the battery clamp nuts, and through the firewall and to the lighter, and of course put a 10 amp fuse in line with it.
But if you use the fuse taps above, you dont have to run extra wires or find a hole in the firewall, etc., so to me, its alot easier and neater for most uses. But if you think cutting into your wires is better, i won't argue.
Old 06-07-2006, 12:07 PM   #15 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
I've seen those cause so many problems in the past. Often times they'll cut through the wire after an extended period of time or just become disconnected. Of course, it usually takes a few years for problems to arise. They won't even use these at Circuit City or Best Buy due to the potential problems. Sure, it may save a minute or two but what if the car comes back and then you need to search around to figure out which one broke? Then you can easily spend hours of time trying to fix it. Smaller shops may use them so that installs are quicker which makes them able to compete a little better with the big name companies, and they often get away with it because they only warranty their installs for a year or two. Still not a good idea any way you look at it.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
DIY- Upgrade and extend stock battery wires Phi Audio, Video, and Security - Tech 37 05-31-2011 01:53 PM
Electrical system gremlins... Valkyrie90AE92 Archived Corolla threads 2 05-14-2006 08:33 AM
DIY Cold-Air Intake bondobondo Hardcore Tech and Competition 40 11-24-2004 01:41 PM
Total Electrical System Failure sargeusmc57 Camry & Solara Lounge 0 12-21-2002 03:55 PM
could you get away with it bondobondo General Discussion 46 07-06-2002 12:00 PM
