Camry quits in reverse - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-05-2006, 06:02 PM   #1 (permalink)
View Folken's Photo Gallery
Canada Camry quits in reverse
Hey and thanks in advance,
My 1995 Camry LE has quit while in reverse twice in the last month.
The first time I was backing out of the drive when it quit, without notice.
I couldn't start it and had it towed to the dealer. They had it for two days because they couln't find a problem. They gave it back no charge.
Well today it quit again, same place as I was backing up and again it was hard to start but it did eventually.
I have tried tonight to duplicate it a dozen times and it never fails.
The tach reads about 900 in park and 7-800 in reverse (without A.C ON).
Any ideas on what I should do to correct this? My wife drives it too and I don't want her stranded.
I talked to the dealer agian today and they have no solution until it quits altogether....errrrrr
don't really want to wait for that...
,,,,,,,,,,,,,,Thanks Folken
Folken is offline   Reply With Quote
Old 06-05-2006, 06:50 PM   #2 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
does it do it on hot start and cold start or does it do it more on the hot than the cold, vice versa?
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 06-05-2006, 08:50 PM   #3 (permalink)
2002 Camry
ToyotaToday's Avatar
View ToyotaToday's Photo Gallery
First of all, are you 100% sure it only quits in reverse. What I'm getting at is... when I drive home at night I park my car in the garage. The next morning I obviously have to reverse to get out.
So, what happens if you back up your car in the garage and then next morning, start the car, and pull out of the garage, does it stall?
It seems kinda odd that it only happens in reverse, as the gears shouldn't really make a difference when it comes to stalling.
2006 4Runner Limited
ToyotaToday is offline   Reply With Quote
Old 06-06-2006, 03:24 PM   #4 (permalink)
it's done it twice and both times it was on cold start, first thing in the morning while backing out of driveway..............tks Folken
Old 06-06-2006, 03:27 PM   #5 (permalink)
yeah, it's happened twice and both times it was in the morning when backing out of the driveway. I have tried to duplicate it, reverse, forward etc. but to no avail. I'm just waiting for it to happen again as the dealer has no solution until it quits permanently.....
....tks Folken
Old 06-06-2006, 03:35 PM   #6 (permalink)
Doctor J's Avatar
Gameroom cash: $261890
View Doctor J's Photo Gallery
Same problem happened to my customer.When the car was placed in gear, a strain was put on the wire harness, as a result, one poorly connected terminal was pulled off, resulting in engine stall.
Start the engine and move wire harness to check for loose connections,etc.
Doctor J is offline   Reply With Quote
Old 06-07-2006, 07:43 AM   #7 (permalink)
Canada
Thanks Doc, but where do I find the harness you mention and the connections?.....Folken
Old 06-07-2006, 10:59 AM   #8 (permalink)
Doctor J's Avatar
This is a thick wire bundle, that runs parallel fo the fuel rail between intake plenum and valve cover, one end of it goes trough the firewall, other branches out to electrical components.
Old 06-07-2006, 04:09 PM   #9 (permalink)
Canada
K, i'LL CHECK IT OUT TKS.......Folken
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
87 Camry trans- no reverse RockWerks 1st & 2nd Generation (1983–1986 & 1987-1991) 8 12-30-2004 02:08 PM
No Reverse!! JSVH Camry & Solara Lounge 5 06-11-2004 11:24 PM
Reverse Glow Guages in a Gen 4 Camry kdrk 3rd & 4th Generation (1992–1996 & 1997–2001) 6 02-10-2004 09:06 AM
