K&N Performance Oil Filter vs Toyota OEM oil filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-05-2006, 07:11 PM   #1 (permalink)
'00 Camry V6 (1MZ-FE)
View NewRacer's Photo Gallery
I went to the dealer and bought an OEM oil filter today, and I kept thinking the lady gave me the wrong one. So, I went to Shuck and bought the filter I've been using just in case, it's the K&N performance filter.
1.) And I immediately notice that the K&N is a lot heavier! The toyota OEM costs about $5, but the K&N cost more than twice, $13. Now I'm thinking, there is no way the OEM is better than the OEM. What do you think?
2.) On the OEM filter, there is a list of engines printed on there, but does not mention 1MZ-FE on it. The part number is 90915-YZZG1, and the engine application:
- 1G series
- M series
- VZ series
- 3S-GTE
- 22R series
- JZ series
- 2TZ-FE
Did the lady give me the wrong one? I told her specifically it's a V6 engine on 2000 Camry. Is the 1MZ-FE engine considered to be M series?
Thanks
NewRacer is offline   Reply With Quote
Old 06-05-2006, 07:17 PM   #2 (permalink)
Ferrat
Ferrat's Avatar
View Ferrat's Photo Gallery
I would like to know, are there any benefits for the engine using a K&N considering there airfilters rock.
Cheers
Matt
1989 Camry SV22 (RIP) Blown Motor
1988 Camry SV21
2001 Camry MCV20 V6 Touring
Ferrat is offline   Reply With Quote
Old 06-05-2006, 07:35 PM   #3 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $280492
View csaxon's Photo Gallery
The numbers change with the seasons and manufacturing locations with Toyota. The G1 is a recent change from the D1, although the G1 has been used in other applications. You can also use the D3 (I prefer this slightly larger filter). The D1 is still available.
As for weight, I suspect the metal casing of the K&N is thicker. That's great if your filter is exposed to flying rocks and other road debris. I don't think that's an issue with your engine filter location.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 06-05-2006, 07:38 PM   #4 (permalink)
Originally Posted by csaxon
The numbers change with the seasons with Toyota. The G1 is a recent change from the D1. You can also use the D3 (I prefer this slightly larger filter). The D1 is still available.
So, do you think she gave me the right filter? My engine is not listed on the filter and I've just done the research, the M series is actually the inline 6 engine family, not the 1MZ-FE V6 engine.
Old 06-05-2006, 07:43 PM   #5 (permalink)
If it was the dealer, then yes, because it was recently changed from the D1 to the G1.
Old 06-05-2006, 07:54 PM   #6 (permalink)
Partnumber 0892202011 was superceded!
Old Partnumber: 0892202011 This was the original in 2000.
New Partnumber: 90915YZZG1
This is from current Toyota factory parts list available to dealers.
Old 06-05-2006, 08:04 PM   #7 (permalink)
So, the one I got is the right one? correct?
Old 06-05-2006, 08:06 PM   #8 (permalink)
Yes.
Old 06-05-2006, 08:18 PM   #9 (permalink)
View freestylez's Photo Gallery
i always used Mobil 1 or K&N oil filters with my Mobil 1 5w-30
it doesnt really matter i can get k&n filtesr for like $8 so it doesnt matter and i always change the filter + oil every 3000-5000 miles anyways
2000 CAMRY CE
freestylez is offline   Reply With Quote
Old 06-05-2006, 08:33 PM   #10 (permalink)
yeuemhoai's Avatar
View yeuemhoai's Photo Gallery
That's the correct one with new part number since I used them for 1MZ-FE V6 of our 95, 96 Camry and 2001 RX300 and 95 Avalon.
I also change oil filter along oil change every 3K miles so OEM filter seems fine to me. Especially at 3.99 if bought in case of 10.
'07CamryLEV6|Whyt|V4|EF|Mudguards|All-weatherMats|LipSpoiler|Tinted|3MProtector|LEDInterior|SERims|Xtreme5000K| LEDTaillights...
'01LexusRX300|PearlWhyt...
'96CamryLEV6CollectorEd.|PearlWhyt...
yeuemhoai is offline   Reply With Quote
Old 06-05-2006, 09:05 PM   #11 (permalink)
Or is Toyota OEM better or K&N? Some say the K&N is too restrictive, but on its official site, it advertize as "high flow rate": http://knfilters.com/oilfilter.htm
I have both at hands now, and the K&N is a lot heavier than the Toyota OEM.
Old 06-05-2006, 09:14 PM   #12 (permalink)
Gameroom cash: $101605
View kenny1773's Photo Gallery
The K&N is an ok filter, just not worth the money IMO. the puralator PURE ONE is the best bang for the buck
but then again, I have known people to run 150,000 miles on crappy Fram filters, so maybe the filter isn't as important as some may think
I use the regular puralator premium filters, pep boys puts them onsale for 99 cents each and I bought about 20 of them at the last sale. I am set for a while. These have shown to be a very good filter for the money, at least as good as OEM
kenny1773 is online now   Reply With Quote
Old 06-05-2006, 09:24 PM   #13 (permalink)
My question is, I have both $13 K&N filter and $5 OEM filter at hands, which one should I use? If the filter is too restrictive, it could affect the engine performance, no?
Is K&N better than the OEM? Or is the OEM better? In terms of engine performance (acceleration, overtaking, etc), I mean.
Old 06-05-2006, 09:28 PM   #14 (permalink)
The Greatest
View CamNub's Photo Gallery
^I don't think there will be any significant difference. Most people go with the K&N though...
CamNub is offline   Reply With Quote
Old 06-05-2006, 09:37 PM   #15 (permalink)
Dominican Republic
Dj-torn's Avatar
View Dj-torn's Photo Gallery
Here is some useful reading on Filters doesn't mention oem or k&n, but it helps in with what to look for..
http://minimopar.knizefamily.net/oilfilters.html
Stock 2002 Camry LE: 2AZ-FE: VVT-i
Dj-torn is offline   Reply With Quote
Oil filter relocation warning! jeffmazz 1st Generation (1995.5–2004) 12 02-19-2009 01:24 PM
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 06:54 PM
OE Toyota oil filter...? HammerDown Archived Corolla threads 41 02-09-2006 08:41 AM
LESS MESS Oil Filter Replacement 73sport Camry & Solara Lounge 13 12-02-2005 09:34 PM
Tools to remove 5gen oil filter? 97&02camryleI4 Camry & Solara Lounge 25 06-04-2004 01:22 PM
