light indicator always on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-06-2006, 08:55 AM   #1 (permalink)
View edmonton99's Photo Gallery
I replaced all the light bulbs that were not working. tested it. everything works fine.
all the front lights and rear lights are working. but the light indicator on the dash board still comes on. whats the problem
1990 2.5L V6 Canadian 25th anniversary http://img501.imageshack.us/slidesho...5625366ym.smil
edmonton99 is offline   Reply With Quote
Old 06-11-2006, 02:19 PM   #2 (permalink)
View toyomoho's Photo Gallery
On cars with dash board light trouble indicator systems, I found light bulb socket corrosion and intermediate contact were often the problem. I end up checking and cleaning the bulb terminals and in some cases replacing them. With your bulbs powered, wiggle them if possible and check for intermediate contact. Remove bulbs and look for terminal corrosion. It just takes a monemtary power contact loss to trigger the light indicator circuit. Terminal corrosion can also increase resistance in the electrical circuit, triggering the indicator light. You could also have a loose or bad wire. It normally only takes one bad terminal, wire, etc. to trigger the system.
Old 06-11-2006, 04:04 PM   #3 (permalink)
View mspringer's Photo Gallery
Carefully check the lights in the trunk lid.
On my gen4, I found that the wires for the lights in the trunklid had broken from the flexing that the wiring goes through each time the trunk is opened and closed. The bulbs might be all good, but make sure they are actually lighting up. (they are parking lights only, not brake lights, so you do not need someone in the car to hit the brakes.
Also, make sure you have the correct bulbs in the sockets you replaced. That might cause a problem, as well. (It may fit, but not necessarily be the right bulb). Make sure everything is lighting up as it should.
mspringer is offline   Reply With Quote
Check Engine Light (again) t4x4_offroad Camry & Solara Lounge 5 10-19-2006 11:52 AM
1990 Camry Check Engine Light Kep Hardcore Tech and Competition 4 05-20-2006 01:15 PM
brake light on dash,, GO AWAY!! alieneyed Celica Forum 13 01-06-2005 01:15 PM
AE92 trunk light mod homeguard Archived Corolla threads 25 04-18-2004 05:50 AM
