will these fit? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-06-2006, 11:41 PM   #1 (permalink)
fungke's Avatar
View fungke's Photo Gallery
Gen5 will these fit?
Hey guys,
can't find IS300 rims so looking at different ones. came across the stock 2004 Acura TL rims.
was wondering if they would fit on my 2003 camry. i am given the following info.
17x8, 5x114.3, +45mm offset
now i know that the bolt pattern matches, not sure about the offset.
help pelase?
03 Camry SE
fungke is offline   Reply With Quote
Old 06-07-2006, 06:06 AM   #2 (permalink)
johnnyzee's Avatar
View johnnyzee's Photo Gallery
yes
johnnyzee is offline   Reply With Quote
Old 06-07-2006, 06:56 AM   #3 (permalink)
fungke's Avatar
thank you.
03 Camry SE
Old 06-10-2006, 12:21 AM   #4 (permalink)
fungke's Avatar
ok...so got the rims, picked up some toyo proxie 4s and when i was getting them installed,
the mechanic told me that the TL's rims were a little different. the hub ring was either a little too big or too small for my car. the rims can be mounted properly...but the little bit of space will cause the car to "shake" a little more at higher speeds. so i took it for a test...he was right...at about 120km/h i could feel the steering wheel shake a little and i think ride quality is also sacrificed in that i feel it was a little bumpier consistantly. i know it's not psychological as my passengers mentioned that they noticed the bumpyness.
is there anything i can do to dampen this?
i am in the process of finding used IS300 rims which i am assuming would fit perfectly but so far no luck. any ideas?
03 Camry SE
Old 06-10-2006, 12:33 AM   #5 (permalink)
View bmxr4life87's Photo Gallery
you need a hubcentric ring, it fills up the gap to make sure your rims fit your hubring perfectly
bmxr4life87 is offline   Reply With Quote
Old 06-10-2006, 12:56 AM   #6 (permalink)
fungke's Avatar
where would i get one?
i asked the guy...but he said that the difference was so minor that they
most likely don't make it....is this possible?
how much do they usually cost?
thanks dor your reply
03 Camry SE
Wheels that will fit! Dseldown 89-95 Toyota Pickup/Hilux 3 02-07-2006 04:51 PM
blinkers dont fit!! Mayne Event Camry & Solara Lounge 6 10-14-2005 06:11 PM
Would a camry motor fit a sienna without any mods? tousi Camry & Solara Lounge 22 10-04-2005 01:30 PM
Witch engines fit the Sienna? tousi 1st Generation (1998-2003) 1 09-26-2005 10:14 AM
HELP! will these rimz fit pk_kk Camry & Solara Lounge 5 06-06-2005 02:42 PM
