Quick shifter? Will it fit? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-07-2006, 12:23 AM   #1 (permalink)
Webb26's Avatar
View Webb26's Photo Gallery
Hmm i've been in the market for a quickshifter set for my g-5 cam. I was looking at the celica trd quick shifter...will fit? Or will anything else fit? Please advise
Webb26 is offline   Reply With Quote
Old 06-07-2006, 12:28 AM   #2 (permalink)
PICKLE GANGSTER
Rdizzle's Avatar
iTrader Score: 6 reviews
View Rdizzle's Photo Gallery
Last i heard is that it will. You need to grind off some where it contacts other parts inside your console.
Originally Posted by DarkMastyr View Post
Is it just me, or has TN just become this massive gay fest? It's like you can't avoid the hot gayness in every thread.
[U]
http://www.cardomain.com/ride/398065...ry-le-coupe-2d
Rdizzle is offline   Reply With Quote
Old 06-07-2006, 11:21 AM   #3 (permalink)
Webb26's Avatar
looks basically the same...i just don't want to spend the money and not have the shifter kit fit. Any other input...ANYONE...i've posted this before but no one seems to know.
Old 06-07-2006, 12:46 PM   #4 (permalink)
MOUTH SLAP!
Your Uncle Moe's Avatar
View Your Uncle Moe's Photo Gallery
My experience with other cars is that you can just cut an inch off the original shifter and weld it back together. Works in the DSM community, see if it does for you.
96 Camry V6 LE & 90 Eagle Talon TSI (AWD TURBO)
"Love is all you need to know and all you need to know is love is all you need to know."
Your Uncle Moe is offline   Reply With Quote
Old 06-07-2006, 02:27 PM   #5 (permalink)
Webb26's Avatar
Interesting...never heard of that. But cutting off the top doesn't achieve too much of a difference in shifting. What i mean is that. the shifter has two ends right? Yes you change leverage..but not by much. THe rear end of the shifter also needs to be changed to allow for quicker shifting right? I don't want to chop and get to the point where it would be hard to shift. BUt hey thanks for your input...i'll look into that one for sure
Old 06-07-2006, 04:12 PM   #6 (permalink)
PICKLE GANGSTER
Rdizzle's Avatar
You can't just chop off an ince and call it a short shifter. It will be shorter but the actual Length Of Throw will be the same, which will make it harder to shift. The trick is to move the pivot point so that the lever under the shift ball is longer than the one on top. If you use your stock one, you would have to cut both sides and move the ball up.
[U]
Old 06-07-2006, 04:29 PM   #7 (permalink)
Webb26's Avatar
THats what i said, lol...but in a different way...If i did change throw by cutting it off, it would be at a minimum or none.
So my ? is how would be able to move the ball...or should i be looking at other shift kits and just do some minor mods so it could fit...but like i stated earlier, i don't want to spend the money and not have it fit.
Oh thanks by the way thanks eveyone for your input...it is much apreciated
Old 06-07-2006, 05:38 PM   #8 (permalink)
PICKLE GANGSTER
Rdizzle's Avatar
You could always try this: http://www.toyotanation.com/forum/t105294.html
[U]
Old 06-08-2006, 01:55 AM   #9 (permalink)
Webb26's Avatar
NIce i'll defintely think abou that one...But hey rdizzle, maybe i can buy a shifter alone without the frame...and then just put it in my frame, and adjust for the difference in length...you think that might work?
Old 06-08-2006, 11:17 PM   #10 (permalink)
PICKLE GANGSTER
Rdizzle's Avatar
You could always try and report back to us.
The trick is getting a shifter that keeps the pivot ball in the same place while extending your moment arm length. I would always recomend messing with just the arm before you start messing with any permanent feature like the shifter frame.
On a side note, you could try to modify one of these to fit. Seems to be closer to what you want. http://www.twmperformance.com/shorts...rtshifters.htm
[U]
Old 06-09-2006, 12:45 PM   #11 (permalink)
Webb26's Avatar
Hey thanks for all your help..when i get time to work on it i'll let you guys know...Hopefully somewhat soon....
Another question, any manual gen5 cams out there that have done this mod?
Stiff shifting with TRD quick shifter Jose123 Archived Corolla threads 1 05-18-2005 03:17 PM
TRD Quick Shifter....How? red2 Archived Corolla threads 4 03-03-2005 03:04 AM
Gen3 TRD Short Shifter install (and NEW fix for a solid feel)... BLUEMEANIE 3rd & 4th Generation (1992–1996 & 1997–2001) 6 05-30-2004 10:51 PM
Will this shifter fit? WhiteRabbit Camry & Solara Lounge 5 05-05-2004 03:21 AM
where can i find a good quick shifter?? 2003rollaS Archived Corolla threads 5 01-24-2004 07:38 PM
