Any suggestions?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-07-2006, 07:30 AM   #1 (permalink)
View jtmcgrat's Photo Gallery
Any suggestions??
Hey all,
I'm new to this forum, but in need of some help. I have a 1992 Camry V6 LE, its got 74000 miles on it, and is in good shape. The AC hasn't worked for as long as I've had it (about 2 years, it was my grandfathers car). I've had it recharged a couple times and it eventually leaks out. Any suggestions on what might need to be done? Also, I had engine mounts replaced last week and as I'm driving around today, steam starts to come from under the hood. The temp gauge was holding steady in the middle, anyone know what might have caused this?
Thanks,
J.T.
jtmcgrat is offline   Reply With Quote
Old 06-11-2006, 12:54 AM   #2 (permalink)
View toyomoho's Photo Gallery
Over time an A/C system can leak Freon. A good A/C shop will attach a vacuum pump to the system and draw the air out. Then check to see if the system holds this vacuum. If not, there is a leak. They should know where to look for leaks. Once the system is charged with Freon, a Freon sensor can be used to see if and where it is leaking out. All this take time, and may cost extra. When you do get the A/C system up and running, try to run it 15 minutes every week to keep the compressor parts and seals lubed.
As to the steam, have you looked under the hood to see what area it was coming from? Was the engine just washed and now this water evaporating? Take caution, steam and coolant are very hot!
Assuming it is coolant, have you checked the coolant overflow tank to see if you are loosing coolant? If the tank is empty, take off the radiator cap and see if you have coolant inside. CAUTION!!! only do this when the engine is cold, as in overnight cold, or you can get a nasty burn from hot water rushing out.
You can have steam from coolant loss without getting a temperature gage rise. This is because not enough coolant has yet to leave the system to cause the water temperature to rise. If the engine really is loosing coolant, eventually the gage will rise. But you do not want to wait that long.
If you see you are loosing coolant, look for signs of coolant leakage. Look around radiator, heater and intake manifold hoses and where they hook up. Also around the engine cylinder head and where it bolt up to the block. I think the radiator on this car has a plastic top and bottom, these can crack.
The steam may or may not be connected with your recent repairs. So, don't assume anything.
Need San Diego restaurant suggestions touringcamry Off Topic 13 10-28-2006 03:06 AM
Need some suggestions with my moped... TacomaDoubleCab Off Topic 6 04-16-2006 12:32 PM
Need some suggestions meng-chieh Camry & Solara Lounge 28 04-22-2005 02:32 PM
Speaker box suggestions Disturbed Audio, Video, and Security - Tech 8 04-18-2005 07:22 PM
Aftermarket alarm systems -- need suggestions CrownRoyal Audio, Video, and Security - Tech 4 07-18-2003 12:18 PM
