Steering lock is giving me the hardest time today.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-07-2006, 04:06 PM   #1 (permalink)
View Muddassir's Photo Gallery
3rd Generation Steering lock is giving me the hardest time today..
I purchsed 92 camry few days before.. Eventhough I found a trick to unlock it, but today, I am trying my hardest from 1 hour and it is not starting..
I tried moving steering as much as possible, no luck yet..
HELP!!!!!!!!!!!!!!!!!!!!!!!
Muddassir is offline   Reply With Quote
Old 06-07-2006, 04:31 PM   #2 (permalink)
View marc780's Photo Gallery
Maybe the key is too worn, try another key; and shoot a little lube in there too. Maybe some quick fix but you need to change the switch i think. Maybe dismantle to column and lube the switch, or loosen its screws and wiggle it some. If you can just get a new switch and change it. These are problemtic sometimes the only way to move a broken switch is to use force...
Old 06-07-2006, 06:46 PM   #3 (permalink)
I dont think key is worn out.. well I had made a duplicate key... but if you are saying, it worned out, the duplicate would also..
what is the quick fix for switch?
Old 06-07-2006, 07:26 PM   #4 (permalink)
jjthenovice's Avatar
View jjthenovice's Photo Gallery
If it's just that the key is worn out, then the dealer can cut a new key without using a duplicate. All they need is proof you own car and then they can get from Toyota the key code to make a new key. I did this on my since departed 95 Camry.
2012 XLE V6 Magnetic Grey Premium HDD Nav Smart Key
jjthenovice is offline   Reply With Quote
Old 06-07-2006, 08:20 PM   #5 (permalink)
Well, I tried using plier to force it, but it didn't work that way either..
Do you still think that it is worn out issue?
Old 06-07-2006, 08:38 PM   #6 (permalink)
Muddasir this is the best i can do without seeing it...an exploded drawing paste from the shop manuals in this forum. They have one for your car its in the stickies when you sign on. http://www.**********s.com/camry/
Just in case your steering column has to come apart some to fix this.
Old 06-07-2006, 09:49 PM   #7 (permalink)
Thanx man
really apriciate it.
Infact, I was reading the same thing. Do you think, If I follow all the instructions, I would bypass steering lock for later on?
Old 06-07-2006, 10:25 PM   #8 (permalink)
02
JMSinMD's Avatar
View JMSinMD's Photo Gallery
What?
Are you saying that your steering wheel is locked and you can't get the car to turn on? You have to pull it in one direction while turning the key to unlock it. Jon.
JMSinMD is offline   Reply With Quote
Old 06-08-2006, 12:26 AM   #9 (permalink)
If you're asking if you can just rip it out temporarily? I dont know.
Old 06-10-2006, 02:41 AM   #10 (permalink)
View toyomoho's Photo Gallery
Before you start taking the car apart, have the dealer make a new key based on your lock number. A good locksmith shop should also be able to make a key from the number on a door lock. I have many keys for my Camry, some work, others don't. Some only work in certain locks. They do wear out! Making a new key from a worn out key (which may work) can result in a key that does not work at all.
Now this is OFF TOPIC modifierLE Off Topic 14 09-06-2005 08:49 PM
whoa....found this earlier today CUCUY Off Topic 4 03-31-2005 05:59 AM
Had Some Free Time Today.... Louisville Show & Share 15 03-19-2005 08:08 PM
autocrossed today for the first time! Xevuhtess77 Auto Cross 8 07-04-2004 04:50 PM
Update on progression on the Wraith!!!! 56K warning Wraith Hardcore Tech and Competition 72 05-08-2004 03:06 AM
