Plastic cleaner for headlights? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-07-2006, 08:17 PM   #1 (permalink)
View eeMmwhY's Photo Gallery
My headlights are pretty yellow, dirty and fogged up. I was wondering if plastic cleaner will work and how well will they work. Where can I get it and how much do they usually cost?
eeMmwhY is offline   Reply With Quote
Old 06-07-2006, 08:43 PM   #2 (permalink)
PICKLE GANGSTER
Rdizzle's Avatar
iTrader Score: 6 reviews
View Rdizzle's Photo Gallery
It will help some, unless the yellowing is caused by UV light degrading the plastic. Then it is yellow all the way through and your out of luck. But it will help. ANy place like ACE hardware will have some for around 5 bucks.
Originally Posted by DarkMastyr View Post
Is it just me, or has TN just become this massive gay fest? It's like you can't avoid the hot gayness in every thread.
[U]
http://www.cardomain.com/ride/398065...ry-le-coupe-2d
Rdizzle is offline   Reply With Quote
Old 06-07-2006, 09:02 PM   #3 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
It's tough to actually make a noticeable difference, unless you clean the insides as well. Some people use fine grade sandpaper and sand it down.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 06-07-2006, 09:08 PM   #4 (permalink)
View keba's Photo Gallery
i used a product called nufinish from walmart. worked wonders for the haziness.made the lenses clear and the headlamps visible
the yellow wont go away but for 2 bucks it is hard to beat. comes in a yellow bottle
keba is offline   Reply With Quote
Old 06-07-2006, 09:31 PM   #5 (permalink)
Dominican Republic
Dj-torn's Avatar
View Dj-torn's Photo Gallery
I had some of the same problem and bought "Meguir's PlastX" some where aroud $4 to $6 depending if its on sale or not.
Stock 2002 Camry LE: 2AZ-FE: VVT-i
Dj-torn is offline   Reply With Quote
Minor scratches on speedometers plastic cover Billzebub 2nd Generation (2005+) 11 09-02-2008 06:32 PM
ACIS is plastic qprint Camry & Solara Lounge 18 06-21-2008 09:37 PM
TACO 05' Front-end Plastic Removal greystoke 2nd Generation (2005+) 1 02-28-2008 12:09 PM
chervon fuel injector cleaner and fuel system cleaner v6secamry Camry & Solara Lounge 1 01-15-2006 06:56 PM
Bluemagic Plastic Cleaner WhiteRabbit Camry & Solara Lounge 2 06-03-2004 04:41 PM
