Weird Front Suspension Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-07-2006, 08:34 PM   #1 (permalink)
Ferrat
Ferrat's Avatar
View Ferrat's Photo Gallery
2nd Generation Weird Front Suspension Problem
G'day all,
Just had a bit of a werid problem with the cam. It seems like when i accelerate or brake sometimes the front wheel, in particular the drivers side, seems to have front/back movement in it. kinda of a shake. Just wondered if anyone had some ideas? I'm thinking maybe FSB? as its the only thing that looks like it stops that.
The other thing was, last weekend i went over a speed hump at only 20km/h and it made a load bang, know my somewhere up the front drivers side theres a rubbing sound coming from there (again thinking FSB). The first problem i've had with the car since i brought it. :P This one is just annoying.
Thanks all
Matt
1989 Camry SV22 (RIP) Blown Motor
1988 Camry SV21
2001 Camry MCV20 V6 Touring
Ferrat is offline   Reply With Quote
Old 06-07-2006, 10:30 PM   #2 (permalink)
Beams SV21
da_horse's Avatar
View da_horse's Photo Gallery
check your lower control arm bushes and your front sway bar bushes. usually these will be shagged by now. just get some mackay replacement bushes at Bursons or Repco, get a shop to put em in and away you go.
rubbing noise? look around where the noise is and see if you can see some rub marks.
Cheers
Huy
1989 BEAMS 3S-GE SV21 Camry
2003 ST246 Caldina GT-Four N
da_horse is offline   Reply With Quote
Old 06-08-2006, 12:36 PM   #3 (permalink)
Doctor J's Avatar
Gameroom cash: $261890
View Doctor J's Photo Gallery
Lower control arm bushing for sway bar are going bad
Doctor J is offline   Reply With Quote
Old 06-08-2006, 10:41 PM   #4 (permalink)
Ferrat
Ferrat's Avatar
G'day,
So is the lower control arm connected to the suspension? I was thinking about replacing the bushes. There only $35 or so bucks
Matt
1988 Camry SV21
Old 06-08-2006, 11:56 PM   #5 (permalink)
Beams SV21
da_horse's Avatar
yes it is. poke your head under the front near the wheel and you'll see what we're talking about
Huy
another noisy front suspension hclee25 Camry & Solara Lounge 1 09-21-2005 01:10 PM
Front Suspension Noise Fix kfss Camry & Solara Lounge 4 09-01-2005 07:08 PM
Gen 3 Weird Overheating Problem and Where to Purchase a Camber Kit htang4 3rd & 4th Generation (1992–1996 & 1997–2001) 9 10-30-2004 06:02 PM
!i!i!i! Weird problem - "Experienced Camry Users" advice needed !i!i!i! DavePont Camry & Solara Lounge 22 10-20-2004 12:13 AM
Kinda weird problem with AE92 Timberland Archived Corolla threads 7 09-17-2004 10:06 PM
