coolant temperature sensor replacement? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-07-2006, 11:35 PM   #1 (permalink)
View smkdwnn's Photo Gallery
2nd Generation coolant temperature sensor replacement?
should i replace my coolant temperature sensors they both have 198,000 miles on it or should i wait ?
smkdwnn is offline   Reply With Quote
Old 06-08-2006, 12:22 AM   #2 (permalink)
View marc780's Photo Gallery
If it aint broke...i'd leave em alone!
Old 06-08-2006, 12:40 PM   #3 (permalink)
Doctor J's Avatar
Gameroom cash: $261890
View Doctor J's Photo Gallery
The plastic part of it usually getting brittle with temperature/aging. Mileage has little to do with these parts. If their color is original, there is nothing to worry. If the color is faded, it is a good idea to get some spare sensors/connector plugs..
Doctor J is offline   Reply With Quote
Old 06-08-2006, 09:00 PM   #4 (permalink)
2nd Generation
the color of the connector is faded but i don't understand your reasoning
Old 06-08-2006, 09:05 PM   #5 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
LOL
Colour has NOTHING to do with it!
Get out your multimeter and TEST the sensors. Make sure they are within the resistive range for the given temprature. That will tell you if they NEED replacing.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 06-09-2006, 08:58 AM   #6 (permalink)
Doctor J's Avatar
Faded color means plastic desintegration. If the sensor is accidentally hit with the tool it may break easy. If not touched, it will work long time even faded.
However, I saw several customers who came with strange problems after distributor cap or coolant hoses replacements, done by careless technicians.
So I made a rule to keep on the shelf some good used sensors, in case above mentioned happens.
Old 06-10-2006, 03:28 PM   #7 (permalink)
2nd Generation
i found a lot of corrosion on my temperature sensor, you guys might want to check to see if your is corroded or not to make sure it's performing to spec
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
