Question: Fuel Filter wont come loose - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-06-2003, 11:31 AM   #1 (permalink)
Here
View Velocity's Photo Gallery
I have tried to remove the fuel filter so i can replace it with a new one on my 3gen V6 last night but it wont come loose. The bolts on the bottom wont turn at all and if i put to much power trying to turn the filter i might end up breaking the metal fuel line. I pulled out the EFI fuse, cranked up the engine and de-pressurized the fuel from it already. But still that approach didnt help. How did any of you guys who have replaced it do it? or am i missing something here? Thanks!
Velocity is offline   Reply With Quote
Old 03-06-2003, 12:39 PM   #2 (permalink)
Newbie
smokey8890's Avatar
View smokey8890's Photo Gallery
Re: Question: Fuel Filter wont come loose
i had the same problem. first you have to take the bracket off the filter. the bolt on the bottom WILL NOT TURN. instead twist the filter. Its a good idea to use something ot hold the fuel line . also use some WD-40 to loosen it firtst.
Do anyone know how hard it is to channge the fuel line? i accidently bent it whille trin to change the fuel filter myself.
I miss my camry....................
smokey8890 is offline   Reply With Quote
Old 03-06-2003, 01:02 PM   #3 (permalink)
ryan7373's Avatar
View ryan7373's Photo Gallery
I had the same problem with my fuel filter... so I took it to a shop and the guy replaced it for me real cheap since I had the parts. It took him a good while but it was soo much easier for him because he just used a lift and had better access. Good luck though, some people have accomplished this feat, many end up stripping the bolt of damaging something though so be careful.
ryan
'98 CAMRY LE I-4
-is300 wheels [FOR SALE in HOUSTON]
ryan7373 is offline   Reply With Quote
