Gaugees going crazy.......Electrical probblem? HELP!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-09-2006, 04:04 PM   #1 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
Gen5 Gaugees going crazy.......Electrical probblem? HELP!!!
My temp gauge is making it appear as my engine is overheated and my tac gauge makes it appear as it is idling 50 rpms higher than it actually is ...this the second time it did it in a week and it is getting me worried... here are some pics..
this is when i pulled over to see if it was realy overheating...i turned the engine off and took my key out and the temp gauge only went down half way and my tac gauge didn't go down all the way.
There is a pic of when i started it up after i was sure it wasn't overheated.
and thats a pic after i disconnected the battery and plugged it back in....magicaly everything is back to normal.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 06-09-2006, 04:22 PM   #2 (permalink)
Gameroom cash: $103555
View laphan's Photo Gallery
Happened to me 1.5 months ago after oil change. I disconnected the battery negative cable and so far it hasn't done anything funky. Since you have the pic, bring it to the dealer and show them that pics (my dealer told me it was fine and told me that it was my fault by doing oil change in a quick lube place).
laphan is offline   Reply With Quote
Old 06-09-2006, 04:29 PM   #3 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gen5
good idea...it happened the first week i got the car as well...i brought it to the dealer and they said that i caused something to go rong......they reset the ecu somehow and it hasn't done it till this week.....it did it twice this week.
Old 06-09-2006, 05:32 PM   #4 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
anyone elts got any ideas to what it could be?
Old 06-09-2006, 08:20 PM   #5 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Old 06-10-2006, 01:57 AM   #6 (permalink)
Dave's
Gameroom cash: $122050
View Dave's's Photo Gallery
Used to be, the usual problem was a loose ground (often near the panel) but these days with ECU's I don't know.
Dave's is offline   Reply With Quote
Old 06-10-2006, 02:15 AM   #7 (permalink)
Gameroom cash: $926800
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Shit's not normal at ALL. Bring it to dealer and see if it's a warentee repair.
5 Lug Corolla WHAT?
Old 06-10-2006, 07:57 AM   #8 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Thanks for the replys....i need an oil change so when i go there this week i will take the pics with me and show it to them.
Old 06-10-2006, 10:16 AM   #9 (permalink)
View karazy's Photo Gallery
The sensor is defective, or there is an intermittent short in the connection/wiring. It may just be a dirty/corroded connector. Next time it happens, try disconnecting it to see if the gauge returns to zero. If it remains high, the short is in the wiring.
karazy is offline   Reply With Quote
Old 01-21-2007, 12:43 PM   #10 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
It just did it again this week, i have videos this time. Now it said my engine was running at 3000 rpms at idle. And 2000 rpms when it wasn't even running. Will post up videos in a lil.
Old 01-21-2007, 02:23 PM   #11 (permalink)
ASE Master, now Realtor
timebuilder's Avatar
View timebuilder's Photo Gallery
I cannot think of this "ghost in the machine" problem that appears in so many cars as being caused by anything but a ground problem. Figuring out why removing the battery ground cable seems to eliminate the problem could get into a lot of electronics esoterica.
If not under warranty, these problems might be addressed by finding the panel ground locations in the service manuals and servicing those grounds by removing wires (battery negative disconnected) cleaning the connectors and the posts or screws, and reconnecting the wires.
If the cars mentioned in the thread are under warranty, certainly approach the dealer first. If there is hesitation, doubletalk, or blaming you, call Toyota and complain immediately, before the car DOES go out of warranty. Document day and time of conversations, and the substance of those conversations, to the best of your ability, including the name and title of those you speak with. Adam Goldfine of AutoScoop recommends you speak to the dealership general manager, as well.
Courage...Honor...Conquer
timebuilder is offline   Reply With Quote
Old 01-21-2007, 08:08 PM   #12 (permalink)
View marc780's Photo Gallery
You too? If theres one thing thats true, you can trust the dealers to give the straight poop, i sure do. My dealer told me if i used a non-toyota oil filter my car would spontaneously combust and then explode.
Old 01-21-2007, 08:14 PM   #13 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gen5
lmao
Old 01-21-2007, 08:16 PM   #14 (permalink)
Originally Posted by Camralon2343
lmao
I 2nd that.
5 Lug Corolla WHAT?
Old 01-21-2007, 08:20 PM   #15 (permalink)
Yes, but did he tell you about the incurable case of "E.D.?"
Intake idea, crazy, could it work? Sam_Bollea Archived Corolla threads 3 08-24-2005 02:16 AM
Holy S*** crazy a** camry drivers(vid) V6LE_CAMRY Camry & Solara Lounge 9 07-24-2005 04:18 AM
Crazy Japanese jdmsuprarhd General Discussion 15 02-25-2005 08:43 AM
My dash lights went out! xavior66 Camry & Solara Lounge 5 08-03-2004 01:38 AM
