Originally Posted by downsouthdx
what parts will i have to get from a 5spd camry?
Shifter assembly
Shifter cables
Clutch master cylinder
Clutch pedal
Brake pedal
Center console?
You may be able to use the clutch master cylinder, clutch pedal, and brake pedal from the Celica. I'm not sure though.
For the axles. You may have to use the inners from the Celica and the outers from your Camry.
The jackshaft (passenger side axle that goes from the mount to the tranny) may be different between the Celica and Camry.
Also the jackshaft from the Celica may not fit into your existing mount.
^ Just some things you'll have to figure out.
