timing belt and mpg - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2006, 09:16 AM   #1 (permalink)
2002 Camry
ToyotaToday's Avatar
View ToyotaToday's Photo Gallery
timing belt and mpg
I was talking to my service advisor at a Toyota Dealer and he said that once I change my timing belt I would get a little better gas mileage. Has anyone experienced this for those of you that have changed your timing belt?
2006 4Runner Limited
ToyotaToday is offline   Reply With Quote
Old 06-10-2006, 09:21 AM   #2 (permalink)
View fat_bastard's Photo Gallery
That is a load of crock. The timing belt has nothing to do with MPG.
fat_bastard is offline   Reply With Quote
Old 06-10-2006, 11:18 AM   #3 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
lol... agreed. go to a different dealer, or a local shop that you can trust.
there is no way you need a timing belt on an 02 anyway... timing belt is recommended for change at 80,000 miles. one of mine broke at 110,000 so you have a little window between 80-100k i'd say.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 06-10-2006, 11:23 AM   #4 (permalink)
Isn't the recommended 60k? Anyway, I had one break when the engine was at 230k and I'd had the car since 106k and have no idea when/if it had ever been replaced. Yay for non-interference engines
Old 06-10-2006, 11:33 AM   #5 (permalink)
I'm a Mac
zoni's Avatar
60k, 80k, who knows... either way, it doesnt need to be right at either mark.
Dave Zoni
Old 06-10-2006, 12:42 PM   #6 (permalink)
MDT Toyota Tech
View BadChicken's Photo Gallery
The 1mz motor will go to at least 120K before it needs replacement as long as you don't encounter a water pump problem
But most people change them out at 90K
BadChicken is offline   Reply With Quote
Old 06-10-2006, 01:55 PM   #7 (permalink)
2002 Camry
I don't need the timing belt yet, another year driving still to go. I have about 118,000 km, and they say change at 140,000. Any way, the original question was, does changing timing belt have an efffect on gas mileage, but sounds like the answer is No.
Old 06-10-2006, 02:34 PM   #8 (permalink)
Let me out of my cage....
HATEnFATE's Avatar
Gameroom cash: $163450
View HATEnFATE's Photo Gallery
It's posssible only becuase of the stretching that a belt experiences over it's life and getting new one would bring your tolerances right back to where they were when it ws new.
Will it make a noticable difference, most likely not but it might. Thats whey there are tensioners there. If the belt never streched you wouldn't need to have a self adjustable tensioner.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
HATEnFATE is offline   Reply With Quote
Old 06-10-2006, 04:33 PM   #9 (permalink)
Gameroom cash: $304355
The answer is NO, it wont increase you mileage if the car is running properly now. The only time it would effect mileage is if the belt had slipped a tooth. You would notice that as the car wouldn't run quite right. The cam timing would be off. As someone suggested above, find another dealer or an independent tech - someone who is honest.
Mike
Old 06-10-2006, 04:47 PM   #10 (permalink)
View shots76's Photo Gallery
Once a month, I get in the mail from dealers, independent repair shops asking me to change timing belt. They want $200 to change a V6 belt, $170 for I4. And the belt costs $35. Do you think selling timing belt is a very profitable business?
shots76 is offline   Reply With Quote
Old 06-10-2006, 05:19 PM   #11 (permalink)
View toyomoho's Photo Gallery
From what I have read, 90K miles for belt changes is "recommended" for 1998 and up Camrys.
A stretched belt will cause the cam/crank timing to be off. This will effect engine operation and performance. Just how much I don't know. Not enough to notice on a street car and not enough to replace the belt before it is time. Unless the car is running poorly and you have run down the problem to a bad timing belt or related components just keep driving.
Old 06-10-2006, 06:22 PM   #12 (permalink)
I'm a Mac
zoni's Avatar
a streched belt will not cause problems at all!!!!!!!!!!
that is what the belt tensioner is for!!!!!!!!!!!!!!!!!!!!!!!! it keeps the same tension and the same timing all the time.
the only thing that could go wrong is the belt jump a tooth, in which case you will notice poor performance linked to improper timing. this will not happen by a "stretched" belt. as they only stretch a TINY bit. biggest thing is wear and cracking with time.
Dave Zoni
Old 06-10-2006, 08:49 PM   #13 (permalink)
View Klutch's Photo Gallery
Shouldn't an 02 be a chain and not a belt????????????
Klutch is offline   Reply With Quote
Old 06-10-2006, 09:17 PM   #14 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
it is definitely belt because it is a 02 V6
only i4 year 2002 + are on chain
bronzemaxell is offline   Reply With Quote
Old 06-10-2006, 11:48 PM   #15 (permalink)
celica2004's Avatar
View celica2004's Photo Gallery
thats true .. i dont believe that .. timing belt has nothing to do with mileage.. he is sucking your money.. you better check with other (reliable) mechanic... Dont forget to kick his AS*S
WTF?
celica2004 is offline   Reply With Quote
1986 Camry Timing lil5speed 1st & 2nd Generation (1983–1986 & 1987-1991) 1 11-07-2005 02:59 AM
Avalon mpg problem ColinM 1st Generation (1995-1999) 17 06-06-2005 04:02 PM
Question about the MPG after replacing the TB stanleyeye Camry & Solara Lounge 8 01-27-2005 10:08 PM
