Gear Lever slightly tight shifting from P to RNDL - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-12-2006, 08:51 AM   #1 (permalink)
View jpbear's Photo Gallery
4th Generation Gear Lever slightly tight shifting from P to RNDL
HI All,
I have a Camry LE 1998 with about 61k on the clock. In recent days I started to feel that the gear shift lever seems a little tight when shifting from P to D or P to any other option. However once shifted to any other mode, the lever shifts smoothly. There is no other problem with the transmission or driving or mileage. Any advice as to whether this tightness / sluggishness is something to be concerned about?
Second, The Transmission oil is brown - its not pink or red. I do know know if any oil change was done in the tranny at 30k, do you think it is advisable to do a transmission flush and refill at this stage? Would there be any danger of 'Fluid shock' by changing the old oil with the new?
Thanks in advance.
jpbear is offline   Reply With Quote
Old 06-12-2006, 06:27 PM   #2 (permalink)
Toyota Parts since 1981
Gameroom cash: $148255
View DOHCammer's Photo Gallery
Originally Posted by jaganpvs
HI All,
Thanks in advance.
If it only has 60k, I would definitely change out that fluid. Fluid "shock" usually occurs to much higher mileage cars with worn clutches. You shouldn't have that problem if the trans functions normally. As far as your tight shifter, I would look at your shifter cable. Try to lube it up at both ends and see if it helps. We sell a lot a Gen 4 shifter cables that break because of this problem.
05 Highlander V6 AWD
170K miles young
07 Camry SE V6 SOLD!!
TRD Dual Exhaust & Air Filter
DOHCammer is offline   Reply With Quote
Old 06-13-2006, 02:01 AM   #3 (permalink)
View CX889's Photo Gallery
Shifter cables? Where is it located because mine has a similar problem.
2010 Venza V6 AWD / Magnetic Grey Metallic / Navi and JBL Package
CX889 is offline   Reply With Quote
Old 06-13-2006, 06:48 PM   #4 (permalink)
camry "durabilty" tester
View brownyy's Photo Gallery
this may sound like a stupid question but when you finish driving and out it in P, apply handbrake then release brake pedal? Only thing i can think is car is rolling slightly though gears and locking, as your handbrake might be a little warn out?
Mine did it, until i tightened it, i had to stop driving foot on brake, neutral, handbrake on, release foot brake (slight roll onto handbrake), put into park...? good luck dude
brownyy is offline   Reply With Quote
Old 06-13-2006, 08:35 PM   #5 (permalink)
Thanks everyone.
Browny, I have to say my hand brake is worn out, atleast it has to be after wifey drove the car 12 miles with handbrake in 'ON'. .
DOHCammer,
Thanks for the suggestion, will go for a tranny flush then. Hope it will work out well.
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 01:12 AM
Gear shift very tight samp55 Archived Corolla threads 9 10-27-2003 06:50 PM
Gear Shift Lever is Locked superdesi Camry & Solara Lounge 8 07-21-2003 09:15 PM
Shifting gear lights not lit icedmetal Camry & Solara Lounge 0 07-10-2003 01:41 AM
rough gear shifting matrix03 1st Generation (2003-2008) 2 06-08-2003 04:51 PM
