doors don't unlock anymore - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-13-2006, 02:24 AM   #1 (permalink)
View fredster34's Photo Gallery
Gen5 doors don't unlock anymore
ok, lemme try 2 explain. i have a gen 5.5. cam. with the engine running, and u shift from park "P" to drive "D", the doors will automatically lock. when you shift from "D" to "P" or neutral, the doors unlock.
well, the doors dont unlock anymore when I shift away from "D". its annoying me becuz i got used to it working before. any ideas as to why it stopped? holler back!
fredster34 is offline   Reply With Quote
Old 06-13-2006, 11:01 AM   #2 (permalink)
Gameroom cash: $284230
View LE05's Photo Gallery
you may have accidently changed the mode. turn the key to on, not touching anything, press and hold down the lock button. The door open indicator will flash anywhere from 1 - 4 times depending on which mode you are on... read in your manual which mode is which. you may have to repeat this several times to get the mode you want.
FYI, mode 2 is all automatic locks off (i use that mode)
LE05 is online now   Reply With Quote
Old 06-13-2006, 11:06 AM   #3 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $590957
iTrader Score: 7 reviews
View xpeed's Photo Gallery
Oh shit, yours unlock when put to P? Mine never did that when I bought new and definitely that doesn't do that on my dad's Gen 5 as well. I'll look into that. It's really bothersome since my last car did that both lock and unlock. Time to hit the manual.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 06-13-2006, 11:16 AM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
^ There are four settings. One is all automatic unlock/lock off. One is lock when shift out of P, no automatic unlock. The other two lock when the car is shifted out of P and unlock either when you shift into P or when you turn the ignition to off.
2007 Camry 2.4L 5M
Compilation: Programming Remote entry for GEN4 camry keithy 3rd & 4th Generation (1992–1996 & 1997–2001) 36 09-05-2009 11:54 AM
Automatic Locking for 2007 Camry iralbuqu 5th & 6th Generation (2002-2006 & 2007-2011) 32 02-09-2008 05:02 PM
Automatic Ignition Controlled Lock & Unlock (How to Enable)?? fgs_gofish 2nd Generation (2005+) 2 10-19-2005 04:48 PM
Group Buy For GT Factory Vertical Doors AutoAccessory Supporting Vendor Sales 0 03-21-2005 09:21 PM
Progressive Door Unlock Ice5 Camry & Solara Lounge 6 09-25-2004 11:57 AM
