Simple quick 3sgte swap question... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-13-2006, 05:21 PM   #1 (permalink)
Cruisin' Colorado
View Turn 180's Photo Gallery
Ok so the 3sgte engine came out of a MR2... which is RWD... so would the stock tranny that would come with a 3sgte motor require RWD or would/does it still work for the FWD Camry?
If the tranny is for RWD then what tranny is the best to use with the motor? I've been reading around on the forum and the 1mz tranny works but isn't that an automatic tranny?
So I want it to be 5 Speed tranny not the 4 speed auto.
Turn 180 is offline   Reply With Quote
Old 06-13-2006, 05:41 PM   #2 (permalink)
Turbo S2000 FTMFW
ECale3's Avatar
iTrader Score: 10 reviews
View ECale3's Photo Gallery
haha...okay.
First, the 3SGTE can be found in the MR2 turbo (RWD) AND the Celica GT-Four(AWD).
Second, the 5Spd used in the MR2 Turbo is the E153, which is the same transmission found in the 5Spd V6 Camry and Solara.
So no, the 1MZ transmission isn't neccessarily a 4spd auto. I would recommend finding an E153 from the Solara or Camry V6.
The worst part of dying is being alive.
ECale3 is offline   Reply With Quote
Old 06-13-2006, 09:28 PM   #3 (permalink)
Cruisin' Colorado
Ok so I found the engine and 5 speed Tranny from a MR2... will this tranny work or should I get the Camry Solara one?
It doesn't say that it is a E153 but it says it's the stock tranny.
Old 06-13-2006, 09:38 PM   #4 (permalink)
Turbo S2000 FTMFW
ECale3's Avatar
um..IIRC it could work (don't quote me though), but most camry owners who need an E153 go with the Solara one.
Old 06-13-2006, 10:48 PM   #5 (permalink)
Cruisin' Colorado
OK Cool thanks!
Old 06-14-2006, 12:22 AM   #6 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
E153 from an MR2 will required revised shift linkages (get them off a Solara/Camry E153). Other than that, it bolts right up no probs, to all VZ engines, MZ engines and S engines.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 06-14-2006, 12:45 AM   #7 (permalink)
Cruisin' Colorado
Awesome thanks everyone for the help!
I'll see what I can find for the "revised shift linkages"... To be honest I've never heard of that/those...
Mind if I ask what are they?
Old 06-14-2006, 01:28 AM   #8 (permalink)
VeeZed
Revised means,, youll need to mod/change them....because the are oriented for RWD (MR2).
So you need the ones the work for FWD, or, somehow change the ones on it.
Old 06-14-2006, 06:17 AM   #9 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^^ See link below, it explains the conversion:
http://www.geocities.com/zegoat2000/e1531.html
"Skoolin' the unlearned!"
Old 06-14-2006, 04:54 PM   #10 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $308075
If you use an MR2 transmission, make sure it came from the TURBO version of the car. The non-turbo MR2 transmission is the same thing (pretty much) as the standard Camry 4-cylinder manual tranny...
It would be cheaper and easier to run the Camry 5-speed, but it may not hold up to the extra power of the 3s-gte as well as the E153 transmission. Either can be used with the right clutch/flywheel/mount combination.
-Charlie
white90dx is online now   Reply With Quote
Old 06-14-2006, 06:33 PM   #11 (permalink)
Cruisin' Colorado
Sweet thanks everyone for the help!
Vvti Vs. 3sgte Swap weaponrcamry Camry & Solara Lounge 5 05-14-2006 01:06 PM
Newbie has Quick Question. Light On AC Button Southernized Camry & Solara Lounge 7 08-15-2005 08:57 AM
jdm 3sgte question pisces38 MR2 Forum 3 01-08-2005 01:15 PM
'94..'97 Corolla 3sgte swap mox Archived Corolla threads 3 03-10-2004 10:39 PM
3sgte swap ??? kmystic16 Celica Forum 1 02-27-2004 08:19 AM
