Dying battery or alternator? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-14-2006, 11:38 PM   #1 (permalink)
R.I.P. Mick Karn
camrydriver7609's Avatar
View camrydriver7609's Photo Gallery
Question Dying battery or alternator?
How can I tell which one it is? The interior lighting is dim all the time if I'm not stepping on the gas. Horn sounds weak. Door locks and windows respond slowly unless I'm in motion or idiling at high rpm's. My friend said she thinks someone left the light on in my car over night but no one can say for sure. The car also doesn't turn on as quick as it always has, especially in the hot sun. Which is it in your opinion? The last time my alternator went out the car was just dead one morning. Bought a new battery and it was dead by the next day. The last time the battery went out was in a parking lot. The car drove fine there and just wouldn't turn back on after being off for about 45 minutes. Should I be looking for any warning lights to come on? Right now there is nothing. Thanks.
'97 XLE V6 - 98% stock.
camrydriver7609 is offline   Reply With Quote
Old 06-14-2006, 11:40 PM   #2 (permalink)
Still confused...
95WhiteCamry's Avatar
iTrader Score: 7 reviews
View 95WhiteCamry's Photo Gallery
Sounds like the alternator since there seems to be a problem re-charging the battery. And as far as I know, there is no warning light for an alternator but there might be a battery light in your camry. The 3rd gen camry had a battery light, not sure of the 4th gen. Good luck!
"live in the moment, forget the past and ignore the future"
Originally Posted by white3ch0c0late
Yes, Alex is the resident woman-problems guy here at TN... take his advice...
'95 i4 camry sedan -> wrecked june of 2006 by a girl who couldn't drive
'95 v6 camry coupe (dropped, rimmed, front end converted, tinted and debadged) -> current
95WhiteCamry is offline   Reply With Quote
Old 06-14-2006, 11:46 PM   #3 (permalink)
2002 Camry
ToyotaToday's Avatar
View ToyotaToday's Photo Gallery
From the sounds of it, it is pointing to your alternator or voltage regulator. The main purpose of your battery is to start the car, once the car has started the alternator takes over. The alternator should have enough current to do everything: charge battery, run all the accessories, etc. When the battery is fully charged, the voltage regulator detects that and stops charging the battery.
Did you try driving your car for a few hours just to make sure the battery is fully charged. Do that first and if you still have a problem, it is likely the voltage regulator, alternator, or alternator brushes.
How old is your battery?
2006 4Runner Limited
ToyotaToday is offline   Reply With Quote
Old 06-15-2006, 12:02 AM   #4 (permalink)
R.I.P. Mick Karn
The battery is about 2 years old. I can't remember if I bought a 24 or 36 month battery. The alternator was changed about 4 or 5 years ago. I called the location where I bought the alternator, as it came with a life time gurantee and as luck would have it they can find no information. I can't believe that.
And yes, I was able to confirm that the morning my car started acting this my mother noticed that the light had been left on since the previous afternoon. Almost 24 hours. It looks like that was the start of all this. It's been like this for almost a month now.
Oh yes, I should also mention that last week my husband left the light on in the car for about 12 hours. Things haven't been worse or better.
Old 06-15-2006, 12:41 AM   #5 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
if you have a voltmeter... check the voltage of the battery it should be around 12.6 with the engine off and around 14 if the engine on... rev the car and check if the voltage if it goes up.. if it goes up higher than 14 your regulator in the alternator might be broken and overcharging the battery and killing it
Old 06-15-2006, 12:53 AM   #6 (permalink)
View toyomoho's Photo Gallery
Leaving the interior light on overnight can lead to premature battery death. The discharged battery never fully recovers and can soon die.
If you have a voltmeter, you can go to the links below and read about testing your alternator and battery. You can pick up a voltmeter for under $10 if you look. They are great to have around.
Some auto parts stores will test your battery and alternator (off the car) at no cost.
If you want to keep abreast of your electrical system, install a car voltmeter and learn how to read it. This can save being stuck somewhere with a dead battery. It will give you a heads up and time to drive somewhere before your run out of juice.
http://www.inct.net/~autotips/altrn.htm
http://www.type2.com/library/electrip/batfaq.htm
Old 06-19-2006, 12:16 AM   #7 (permalink)
R.I.P. Mick Karn
Well I don't have a voltmeter but I might buy one tomorrow after reading this. I turned on my car and my brother disconnected the battery. The car kept on running. Even sounded better than before. The A/C and interior lights were looking better too. We drove down to Checkers/Kragen and had some guy come out and test the battery. He said the voltage was at 10.7 before the car was on and started falling after I turned it on. He said the low voltage wouldn't allow him to get a proper reading (?) and that he was pretty sure it was the alternator. When all was said and done the voltage meter he had gave him a reading of 9.5. He also told my brother that the "unplugging the battery" trick wasn't acurate for newer import cars like it was for 70's something domestics. I'm going to take it to another place and have them check out both the alternator and battery this time. For those of you who did have your alternator and or battery die on you, did you get a warning light come on your dash? I do have a light for the battery but it hasn't come on.
Thanks for the replies and keep them coming!
Old 06-19-2006, 12:43 AM   #8 (permalink)
View marc780's Photo Gallery
The battery's probably on the way out, 2 times at the most you can kill it and recharge and then its a bookend.
When you change the battery, check your clamps too, they need to be (fairly) tight. In other words, if you try to twist them, they should NOT move with moderate effort. If they are loose, you can shim them with a thin piece of metal like a eletrical connector.
Old 06-19-2006, 09:48 AM   #9 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
Yeah check it w/ a voltmeter and that should give you some indication.
http://www.xclusive.bz
Old 06-19-2006, 10:08 AM   #10 (permalink)
View hooRAH's Photo Gallery
Sounds like the voltage regulator to me.
The voltage regulator does not "turn off" the alternator when the battery is charged. The voltage regulator varies the voltage output of the alternator depending on the RPM the engine is spinning at. Without one, the faster you spin the engine, the more electricity is generated from the alternator (that would be bad).
Because you state that the lights brighten when the engine is revved, the voltage regulator is not doing its job. I would replace that.
As for pulling the positive cable off of the battery to test, that is generally frowned upon because you loose the capacitance of the circuit that the battery provides. Alternators are not an exact science, the voltage they put out goes all over the place. The battery keeps that voltage more stable. Removing the battery can cause large enough fluctuations in voltage to damage the ECU. I've seen it done before, and most of the time, it does work. Its just not something I'm going to risk or recommend.
In the mean time, I would try to charge your battery overnight using a bench charger. It should give you a few days of normal operation until you get the voltage regulator fixed.
01 BMW 330Ci - 5spd / 93 BMW 525i 5spd-SOLD/ 98 Camry LE
hooRAH is offline   Reply With Quote
Old 06-19-2006, 10:11 AM   #11 (permalink)
93 240sx SR Hatch
DAMON's Avatar
iTrader Score: 36 reviews
View DAMON's Photo Gallery
the battery light never came on when mine died in my gen 3, if that helps
94 Camry (Beater) 99 Solara (Totaled) 93 240SX (Current)
DAMON is offline   Reply With Quote
Old 06-19-2006, 10:31 PM   #12 (permalink)
R.I.P. Mick Karn
Is that the little blue thing where the fuses are? The guy who tested my batter took it out and looked at it and said it was fine. I don't know though.
Old 06-20-2006, 07:16 AM   #13 (permalink)
No. The voltage regulator is built into the alternator. It should be covered under the lifetime warranty of the alternator itself. If you can't get the warranty, its only like $35.
Old 06-20-2006, 08:12 AM   #14 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
Gen5
unplugging the battery when the engine isn't the smartest thing to do . It can cause shorts, fires and a whole bunch of other problems.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 06-20-2006, 09:07 AM   #15 (permalink)
Doctor J's Avatar
Gameroom cash: $261890
View Doctor J's Photo Gallery
The ASE tutorial recommends quick alt/battery check:
  1. Before starting the engine, measure voltage on the battery terminals
  2. Start the engine. Run it at 2000 rpm, measure voltage again
  3. With accesories off it must be not higher then result of step 1 plus 2 volts
  4. While keeping the same rpm, turn the accesories on and measure voltage, it must be no less the step 1 plus 1 volt.
Measure voltage between neg. battery post and shassis ground with high beams on, engine running at idle. The result must be less then .2 V. If it is more, clean ground cable connections and re-test.
Do the same test with B+ terminal of the alternator and positive battery post. Again, if the result is greater then .2 to .3 volts, check the connectors. With digital meter polarity is not critical, just select DC volts.
Doctor J is offline   Reply With Quote
New battery dying on 2001 Avalon Ottoale 1st Generation (1995-1999) 2 04-17-2006 08:23 PM
More on this damn car battery! speedemn Camry & Solara Lounge 14 01-01-2006 09:21 PM
02 Sienna- alternator and battery WeileMom 1st Generation (1998-2003) 1 11-29-2005 09:25 AM
Alternator or dead battery? camry_98_owner Camry & Solara Lounge 8 09-11-2005 11:28 AM
Battery ?'s 1995 camry V6 LE kenny1773 3rd & 4th Generation (1992–1996 & 1997–2001) 14 11-29-2004 03:29 PM
