Low Air pressure indicator - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-15-2006, 04:01 PM   #1 (permalink)
View iralbuqu's Photo Gallery
Canada Low Air pressure indicator
Does any one know how I can identify if my 2007 Camry LE V6 has a low Tire Presure indication?
iralbuqu is offline   Reply With Quote
Old 06-15-2006, 04:09 PM   #2 (permalink)
View Klutch's Photo Gallery
Not sure on the Canuck version but mine has a little low tire indicator on the dash lights. When you turn you ignition on you dummy lights go through what is essential a POST where they all come on, see if you have that light. If so you should have it. Also the owners manual and check your valve stems, my cap is plastics but the stem is aluminum and different than anything else I've ever had, it's noticeable.
My indicator is in the lower right of the cluster. It's yellow when it lights up and looks sorta like a flat tire.
Klutch is offline   Reply With Quote
Old 06-15-2006, 04:19 PM   #3 (permalink)
View toyomoho's Photo Gallery
I thought this was standard equipment on 2007 LE for USA. Can't say about Canada.
Old 06-15-2006, 04:26 PM   #4 (permalink)
It was mandated in the US in 2006. I also don't know about Canada either. I do know Toyota want $100 each for replacements. HAHA
GM sells theirs for $30 a piece...
Old 06-15-2006, 04:39 PM   #5 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Did you get a window sticker or is that only in the Great USA.
or a brochure or a Toyota Canada website?
Low Fuel Indicator Light on '97 Camry? Camry97LE 3rd & 4th Generation (1992–1996 & 1997–2001) 5 05-28-2006 06:09 AM
Low oil pressure after timing belt & oil pump seal change Hot66ss Camry & Solara Lounge 9 05-07-2006 08:44 AM
86 mr2, low oil pressure? YOU VIEW NOW!! mr2poweraw11 MR2 Forum 5 08-21-2005 01:05 PM
low air sensor on tires ewrob General Discussion 6 11-20-2004 06:20 PM
Low Profile Tires..... What is an indicator that they need m danny67x Camry & Solara Lounge 0 05-20-2002 10:35 PM
