I was trying to change out my fuel filter today on my 96 camry (4 cyl) but didn't have much luck removing the bottom bolt. There isn't much clearance to work with and I was wondering how other people did it.
I took some pictures just to clarify what I am talking about. It appears the bottom bolt isn't a bolt at all. Or is it?
What kind of wrench did you use on that? i hope you didnt use an Crescent wrench,
they ruin more bolts and nuts than any other tool out there, in my opinion its a tool
of last resort. A flare nut wrench should do the trick if you can get it to seat properly.
The above posts list the right thing - a flare nut wrench. But, if you (or someone before you doing it) has buggered it up like mine was, you may need to break down and use what I did - some vise-grips or a pipe wrench - although this will bugger it up a little bit more and any future changes will require the same tool - penetrant helps too. Just thought you should know there is an alternative if even your flare-nut wrench rides around it like mine did. Best of luck.
Yup, use a flare wrench
it will give you better grip.
Get a set from Sears. They sell like a set of 4
U will need two of them. One to grip the top bolt which is actually the fuel filter that is posted in ur picture (black color).
The other is to grip the bolt you might have stripped...
In addition to the flare wrenches which are absolutely necessary to avoid damaging this kind of fitting, you might try soaking it with some penetrating oil such as PB Blaster, Kroil, or CRC. Letting it soak over night would be a good idea. If that fitting gets buggered up it will be a real pain to repair.
FWIW
YMMV
I justreplaced my fuel filter yesterday. All I used was those same kinda wrenches. The one that gave me problems was the top one, cuz I didn't have the size to hold the fuel filter while I loosened the bolt. I had to grip that shit wiht a vise then loose the bolt.
After some tools and running around to Sears and Advance Auto Parts, I was able to change it out.Fortunately it was not stripped as I might have thought but I was able to tighten it back to spec when I installed the new filter. I haven't noticed anything different before and after even though the original filter was on for 136,000 miles. Any of you guys notice anything? My car didn't have any problems initially but I changed it out as a routine maintenance procedure. Again, thanks for all of your input.
