One question after replace distributor O-ring - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-17-2006, 08:37 AM   #1 (permalink)
View popeye08's Photo Gallery
3rd Generation One question after replace distributor O-ring
The engine oil leaks from the O-ring. The higher speed the more leak. This morning I replaced the distributor O-ring. I marked the outer house for reinstallation. But when I took off the distributor, old O-ring and installed new one, I messed up the angle of the shaft. Then I just turned the shaft to fit the inner groove, and the engine now works fine.
My question is if it is possible that the shaft could have been turned 180 degree and still can be insert and work but I cannot tell the difference? Thanks in advance!
popeye08 is offline   Reply With Quote
Old 06-17-2006, 08:51 AM   #2 (permalink)
TheWhiteKnight's Avatar
View TheWhiteKnight's Photo Gallery
Australia
It's in there right as the dissy wouldn't fit in if you had it 180 degrees out.
The slot in the cam end and the 2 teeth on the dissy WONT line up.
Cheerz.
'Opinions are like a##holes, everybody's got one!'
__________________________________________________ ____________
1988 SV21 Sedan, 3SFE, 5spd manual, 17' rims.
1989 SV21 Sedan, 3SFE Auto, 15' rims.
1985 RA65 Celica (hatch) 22REC, 5spd manual.
TheWhiteKnight is offline   Reply With Quote
Old 06-17-2006, 08:57 AM   #3 (permalink)
Dont know this. Great! Thanks a lot!
Ring Gear ROBS Camry & Solara Lounge 17 05-07-2006 10:40 PM
A story about my school class ring... epinionator89 Off Topic 6 08-20-2005 06:20 AM
Suspension install question CDub LXi Camry & Solara Lounge 7 02-13-2005 12:09 AM
engine/timing belt question. slikk Introduce Yourself Here 2 02-02-2005 11:42 PM
Question on piston ring replacement Ho Siam Yong Archived Corolla threads 9 01-28-2005 12:31 PM
